Putting a factory sway bar on a Std. Civic hatch?
Old May 3, 2007 | 05:31 PM
g2b2's Avatar
Default Putting a factory sway bar on a Std. Civic hatch?
I searched the FAQ for the sizes of sway bars and found that my hatch apparently doesn't have a front sway bar since it is a standard model. If I found a higher level civic and took the sway bar off of it, would it be a direct fit on my car? Thanks
Old May 4, 2007 | 05:10 PM
g2b2's Avatar
bump
Old May 4, 2007 | 05:39 PM
rexxb16's Avatar
Default Re: (g2b2)
yes direct fit i asked the same question 1 month ago the sedan ones are suposed to be thicker
Old May 5, 2007 | 05:26 AM
g2b2's Avatar
sweet, so if I find a sedan in a junkyard I can just rip it off of that and all the mounting holes and everything will ling up?
Old May 5, 2007 | 06:13 AM
jlicrx's Avatar
Default Re: (g2b2)
not a direct bolt-on - the STD lower control arms have no place to bolt the sway bar onto
Old May 5, 2007 | 07:17 AM
esteen2's Avatar
Default Re: (jlicrx)
I have a std and it has the holes in the control arms for the sway bar.
Old May 5, 2007 | 07:25 AM
CRXBart's Avatar
Default Re: (S2R Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2R Honda &raquo;</TD></TR><TR><TD CLASS="quote">I have a std and it has the holes in the control arms for the sway bar.</TD></TR></TABLE>
Yes I think the above guy was thinking about the rears.
BTW bigger front sways are not always better. I would recommend the hollow HF unit. You want a big back bar, and a small front.
Old May 5, 2007 | 09:42 AM
g2b2's Avatar
yea, I'm looking to put on a front sway bar and if i find a rear it would be cool too. So could I get one off of a sedan or something and just transfer the brackets and stuff and just bolt it onto my car without havening to drill anything?
Old May 6, 2007 | 04:16 AM
g2b2's Avatar
Default Re: (g2b2)
sorry i pretty much repeated what i asked further up, I'm just gonna go buy one from the junkyard and see what happends
dkrex001
Dec 15, 2006 03:54 PM
Dragger817
Dec 21, 2003 12:11 AM
Kilohead36
Apr 14, 2002 04:02 PM
DreamSpeed
Oct 20, 2001 11:10 AM
