2 questions: What's your tire pressures and SRS light?
Just curious as to what everyone's tire pressures are for street tires? I just had 205/50/15 Kuhmo Ecsta's put on. The car was pulling to the left at first so I had them re-align the car. It is ok now but still seems a little squirmish. Maybe it's the tires anyone have any similar experiences with the Kuhmos? Also my SRS light has been on for a while. I was wondering if it is maybe because of the passenger airbag cut off switch that is installed in my car. The problem is I don't know where it is located thus can't turn it on or off to check. Anyone have this? All i know is that there was a receipt for the switch in some of my documentation that came with my car.
thanks
Amit
thanks
Amit
37/35 - I run 205/50-15 RE730s.
205s will feel a bit "squirmy" vs. 195s on stock rims. Stiffer sidewalls and slightly higher pressures help balance that out.
Not much point in having a SRS bypass switch you can't find... but that's probably your culprit. I'd check the resistance throught that switch. Get out your Helms and trace the wiring back and you'll find the switch, I reckon.
I like my tires kind of hi... use a 205/50/r15 n I run the front ot 35 and the back at 37 ( daily driving) .....
yea i konw
yea i konw
