d16y7 dual point question.
Old May 3, 2007 | 01:09 PM
the1337couch's Avatar
Default d16y7 dual point question.
i want to do a mpfi conversion cuz i have a dx crx. it has a d16y7 form a 96 civic but it is dual point. do y7s come dual point or is it just the dual point mani on it. and can i just put a multipoint mani on it with out having to swap the dizzy?
Old May 3, 2007 | 01:11 PM
Ermil's Avatar
Default Re: d16y7 dual point question. (the1337couch)
FAQ and searching are your friends.
Old May 3, 2007 | 01:12 PM
garageEF's Avatar
search for "mpfi swap" you will find EVERYTHING you want to know
Old May 3, 2007 | 01:45 PM
i know how to do the swap i just dont know if i need to get just the mani or the mani and the dizzy. i know the dizzy for a dual point is different from the dizzy of a multipoint.
Old May 3, 2007 | 02:04 PM
HBK's Avatar
HBK
Default Re: (the1337couch)
If your still running obdo, then you'll need a crx/civic si dizzy, along with the intake mani, fuel rail, etc etc. I'd also recomend looking for a si throttle cable. Then you gotta do all teh wire harness stuff and ecu.
Old May 3, 2007 | 02:09 PM
AK_CRX's Avatar
to do the multi swap you will need intake manifold, ecu and matching distributor. D16y7's never came dual point, but they came with a funny intake manifold that resembles dual point. Somebody probably just put the 88-91 dpfi manifold on the y7 to simplify the swap. Its just like doing an mpfi conversion on a stock DX EF
Old May 3, 2007 | 02:12 PM
cool. i have a pm5 ecu right now but i also have a pm6 ecu layin around so is that the ecu i will need for the swap? or would it just be better to put y8 head on it?
Old May 3, 2007 | 02:37 PM
garageEF's Avatar
you obviously have no idea how to do the swap if you dont know what parts are needed.
Old May 3, 2007 | 03:29 PM
it just didnt make sense that they put a 96 y7 in my car and put the 91 dx dual point mani on it.
Old May 3, 2007 | 03:55 PM
HBK's Avatar
HBK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the1337couch &raquo;</TD></TR><TR><TD CLASS="quote">it just didnt make sense that they put a 96 y7 in my car and put the 91 dx dual point mani on it. </TD></TR></TABLE>
It can make certain sense from a certain perspective.
If I had a fresh y7 motor and I wasn't interested in purchasing a manifold, TB, ecu, wire harness for parts and dizzy, I'd continue to run the DPFI manifold and enjoy the clean running motor.
If you want to do the mpfi swap, do a search.
If you want to swap the head for y8, locate a y8 intake manifold, and do a mpfi swap.
cgross
Dec 18, 2012 06:52 PM
8dxhatchy8
26
Feb 3, 2009 07:41 PM
4thgenhothatch
Mar 28, 2005 04:26 AM
Desert_Rex
Jan 19, 2005 01:30 PM
91d15hatch
11
Apr 28, 2004 10:47 AM
