***NEED HELP CIVIC FUEL PUMP PROBLEM****
Old May 3, 2007 | 12:42 PM
vtikilla's Avatar
Default ***NEED HELP CIVIC FUEL PUMP PROBLEM****
Hi
i am new to the forum and im form the UK
my 92 civic vti seems to be having problems, so can anyone help
the car is usually absolutely fine but some times the car stops moving, i mean the car is still on it hasnt turned off
the exhaust makes blowing noises
the rev counter start bouncing the car will be running for example 2000rev but it will move up and down for no reason
its as though theres no energy in the car
i can smell fumes from the exhaust quite a bit im sure thats not usual
i have been told that it could be the fuel pump but when i get to a mechanic it seems fine
happened two or three times now im driving and it starts playing up on me
can somebody help me out as it would be much appreciated
also you dont suppose if it is fuel pump that i could get a 92 prelude vtec fuel pump on the civic
THANKS
Old May 3, 2007 | 12:51 PM
1995Civic's Avatar
Lets take one step at a time....
When you say the exhaust makes blowing noise, what do you mean by that? Do the fumes smell sweetish at all?
If your RPM's are bouncing like that, it could be you IACV or FITV (although im not sure if that model has a FITV).
Give more info on at least those two things i pointed out.
Old May 3, 2007 | 12:54 PM
fastautoworks's Avatar
Default Re: ***NEED HELP CIVIC FUEL PUMP PROBLEM**** (vtikilla)
is your service light on? check yr spark plugs condition see if it's black.
Old May 3, 2007 | 01:03 PM
vtikilla's Avatar
right i have just had the car serviced three weeks ago
new spark plugs and filters
when i say blowing noise as in just a little spitting noise when i put my foot down on the accelerator, like a farting noise if you will
the fumes smell of like petrol its been like that since i got it which was a month ago, the middle pipe was cracked so i put a ful exhuast on could smell the petrol fumes then aswell
the car actually dirves and everything but out of the blue it messes up, usually when lower on fuel
thanks for your help
Old May 3, 2007 | 01:07 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtikilla &raquo;</TD></TR><TR><TD CLASS="quote">right i have just had the car serviced three weeks ago
thanks for your help</TD></TR></TABLE>
Did you change your fuel filter?
Any CEL? Are you running a Cat?
Old May 3, 2007 | 01:12 PM
vtikilla's Avatar
Default Re: ***NEED HELP CIVIC FUEL PUMP PROBLEM**** (1995Civic)
Yes new fuel filter, when the mechanic had a look he said the engine is perfect he said that there was nothing wrong with it at all, my uncle is also a mechanic i told him the symtoms over the phone he said it souns like fuel pump so i dont know
and yes i have a cat
thanks
Old May 3, 2007 | 01:41 PM
it's posible that yr fuel pump is no good. check fuel pressure. is yr check engine light on? i know the plugs r new but if u can tell me the condition color of the plugs.
Old May 4, 2007 | 06:33 AM
vtikilla's Avatar
Default Re: ***NEED HELP CIVIC FUEL PUMP PROBLEM**** (fastautoworks)
right i called out the AA and the guy said its not fuel pump he said it most definately will be the distributor
what do you think
Old May 6, 2007 | 11:14 PM
Vrooomski's Avatar
Bump let me know if you find out whats wrong im having the same problem.
Old May 6, 2007 | 11:30 PM
lek9l's Avatar
The bouncing of the rpms could be the fast idle air control valve or the iacv or it could be air in the coolant lines or it could be not enough coolant in the lines or it could mean you have a vacume leak somewhere like in the brake booster or a bad seal somewhere or a bad map sensor but usually its the fast idle air control valve or not enough coolant or bubbles in the coolant. The fumes could be the headers connected to the exhaust might be leaking from there or your running too rich you have a leak somewhere in the lines. If your check engine light is on look up the code .
No power, do a compression test on all the cylinders, If it stops moving and makes sounds it might be your clutch disc is already burned out and is rubbing it raw inside. Could be your clutch isn't grabbing. If the fuel pump works and fits on the civic it should haven't have a problem. The computer controls the amount of fuel going in . Sounds like your ride needs some tune ups lol
Old May 6, 2007 | 11:46 PM
Vrooomski's Avatar
thats what i was thinking my clutch isnt grabbing but i have a new clutch.
Old May 7, 2007 | 04:16 AM
vtikilla's Avatar
Default Re: (Vrooomski)
Right i put a new distributor off my other vti on to it and now it seems fine it sparks up a lot more efficiently and revs seem to be running sweeter, so hopfully should be ok now
I would say gt you distributor checked may be a fault inside it
Old May 7, 2007 | 07:59 AM
Vrooomski's Avatar
for sure so you got a whole new dizzy?
Old May 8, 2007 | 09:29 AM
vtikilla's Avatar
yep whole thing including cap, running fine now
classdork987654
Jan 1, 2009 01:16 AM
cacahead1
Sep 3, 2006 07:53 PM
jwatheyjr
Aug 12, 2005 04:13 AM
ninetyfourgsr
Jul 3, 2002 11:21 PM
