What Headgasket to use on d16z6 for nitrous? Y8? Z6? aftermarket?
Old May 3, 2007 | 12:13 PM
-HONDA-'s Avatar
Default What Headgasket to use on d16z6 for nitrous? Y8? Z6? aftermarket?
okay i need too replace the headgasket on my d16z6 its eating up coolant slowly, so i have a nitrous kit for it but i wanted too find out if i should replace the headgasket and use the Y8 or just OEM or any aftermarket one? Let me know you guys i plan on just using a 55 shot on it! anything else i should do?
Old May 3, 2007 | 12:20 PM
Hybrid96EK's Avatar
Default Re: What Headgasket to use on d16z6 for nitrous? Y8? Z6? aftermarket? (-HONDA-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">okay i need too replace the headgasket on my d16z6 its eating up coolant slowly, so i have a nitrous kit for it but i wanted too find out if i should replace the headgasket and use the Y8 or just OEM or any aftermarket one? Let me know you guys i plan on just using a 55 shot on it! anything else i should do?</TD></TR></TABLE>
Z6. I Heard the Y8 one is cheaper and works the same. No need for aftermarket. Worry more about the headbolts and lifting the head then the gasket dying.
Old May 3, 2007 | 12:22 PM
-HONDA-'s Avatar
so are you recomending some headbolts? ARP head studs? i can get some but how do you put them in lol.....any instructions how do you tighten them onto the block?
Old May 3, 2007 | 12:57 PM
suspendedHatch's Avatar
Default Re: What Headgasket to use on d16z6 for nitrous? Y8? Z6? aftermarket? (Hybrid96EK)
Z6 and Y8 are now the same part. Please don't rely on 5 year old information. A quick check over at Majestic Honda is all the proof you need.
OEM gasket is fine but there are stronger aftermarket gaskets available from Cometic and HKS.
I third the ARP head studs idea.
Old May 3, 2007 | 01:12 PM
Vaw7er's Avatar
Default Re: What Headgasket to use on d16z6 for nitrous? Y8? Z6? aftermarket? (suspendedHatch)
Yeah Z6 is pretty stout... if its leaking or smoking coolant then you should tune better.. lol.
Old May 3, 2007 | 01:38 PM
HXvtec's Avatar
Default Re: (-HONDA-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -HONDA- &raquo;</TD></TR><TR><TD CLASS="quote">so are you recomending some headbolts? ARP head studs? i can get some but how do you put them in lol.....any instructions how do you tighten them onto the block?</TD></TR></TABLE>
they should come with torque specs. simple to install. when you take out your stock studs just put in the ARP the same way you took them out.
Old May 3, 2007 | 03:44 PM
smileycvc's Avatar
Default Re: (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">
they should come with torque specs. simple to install. when you take out your stock studs just put in the ARP the same way you took them out.</TD></TR></TABLE>
Honda's dont come stock with head studs they come with headbolts.
get head studs and tighen them with the head off. Take an allen key and tighten the stud down until its snug/tight. Then put the head on and all the washers over the studs. Then put the nuts on and torque them to spec. Good job now you have headstuds.
Old May 3, 2007 | 08:44 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Z6 and Y8 are now the same part. Please don't rely on 5 year old information. A quick check over at Majestic Honda is all the proof you need.
I third the ARP head studs idea.</TD></TR></TABLE>
Majestic Honda's website doesn't list actual Honda part numbers... So before you come off quite so pissy about my "5 year old" information, please gets yours straight as well. A quick glimpse wouldn't have confirmed anything for me.
krysted9354
Mar 23, 2009 07:19 PM
175Shot4Door
Oct 31, 2006 07:00 AM
burnt_rice
Feb 3, 2005 05:48 AM
mugenwannabe
Apr 17, 2004 01:25 PM
DRKSol
Sep 5, 2003 07:05 PM
