Clunking help please
Old May 3, 2007 | 11:18 AM
gsrcivic619's Avatar
Default Clunking help please
What's going on guys, I just did an ls swap into my ek, about a week later i began to hear a clunking sound coming from under the car. I'm guessing it's my wheel bearing. When i turn left the clunking slightly goes away. To add to my frusterations, when i shift gears there is a HUGE clunking coming from under my car. I feel my shift linkage move when i shift gears, it feels like the tire is either coming off the floor or the motor is completely shifting under my hood. I've checked the mounts and they are on securely. If anyone could help out with suggestions, it would be greatly appreciated. Thanks.
Old May 3, 2007 | 11:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
You've checked the mounts are on securely, but did you look closely and make sure the rubber isn't busted? This sounds JUST like broken mounts.
Old May 3, 2007 | 11:25 AM
TDSI99's Avatar
Default Re: (DaX)
it does sound like the rubber in your mounts are bad. The obviously arent doing their job
Old May 3, 2007 | 11:27 AM
Default Re: (DaX)
When i get off of work, I'll pop my hood and rev my motor to see if i see any movement. Could a bad wheel bearing make the tire come off the ground when i shift gears? Also if the shift linkage wasn't on securely could the gear shift clunking be coming from the linkage?
Old May 3, 2007 | 11:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (gsrcivic619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic619 &raquo;</TD></TR><TR><TD CLASS="quote">When i get off of work, I'll pop my hood and rev my motor to see if i see any movement. Could a bad wheel bearing make the tire come off the ground when i shift gears? Also if the shift linkage wasn't on securely could the gear shift clunking be coming from the linkage?</TD></TR></TABLE>
Any of those scenarios are possible. A bad wheel bearing typically sounds like REALLY bad dragging brakes though.
Old May 3, 2007 | 11:39 AM
Default Re: (DaX)
so if i make a left and the clunking stops, would that mean the driver side bearing is bad or passenger?
Freezen
Feb 13, 2010 11:08 PM
showcivic2001
Sep 17, 2008 05:06 AM
91EF_Si
Sep 27, 2007 07:09 PM
psdvette
Apr 22, 2007 12:42 PM
manyakiexpi
Mar 16, 2006 12:25 PM
