...And why I love honda-tech
Old May 3, 2007 | 11:17 AM
DESTROYER's Avatar
Default ...And why I love honda-tech
Thanks guys for all the tips and tricks!
In the end, knowledge is always owned by skill.
So to all those guys that want to know "how to tig weld", PRACTICE!!
Modified by DESTROYER at 5:47 PM 5/6/2007
Old May 3, 2007 | 11:19 AM
tepid1's Avatar
Default Re: ...And why I love honda-tech (DESTROYER)
Not too shabby.... a bit undercut in some areas and maybe a bit hot. Otherwise it looks good.
Is that a Chevy Avero?
Old May 3, 2007 | 11:22 AM
DESTROYER's Avatar
lol yep, an Aveo. It is a tad undercut on the mani in a couple (2) spots.
Thank you, BTW
Old May 3, 2007 | 05:15 PM
arcboy's Avatar
New User
Default Re: (DESTROYER)
A bit cocky don't you think? Yep you still need some practice! Looks good though.
Old May 4, 2007 | 11:28 AM
kid-honda's Avatar
Iregular HAZ. Common term you will hear welding(heat affected zone) you see the heat rings, you want to try your best to keep them minimal well getting full penetration and they should remain tight, even and the same shade
Undercut. This usually means your going to fast or not adding enough filler, if you have proper penetraion you need more filler if your not getting the desired penetrition slow down if needed its fixable with a clean up pass which would be another pass around or just where needed. But concentrate on avoiding needing to clean up undercut.
Pattern not vary tight. This is telling me your speed is alittle fast, the "dimes" look everone wants has to be held vary tight and takes time so dont worry about slowing down and taking your time.
You want a constant pattern in the "dimes" and they should be tight as possible.
Other then that you getting it for a starter.
Lets see the backside for penetration and a better idea on how your running.
Modified by kid-honda at 10:33 AM 5/5/2007
Old May 4, 2007 | 01:09 PM
ManBearPig4silly's Avatar
*golf clap*
Not bad for a beginner. Try welding more than an inch at a time.
Old May 4, 2007 | 02:22 PM
91jdmhatchback's Avatar
Default Re: ...And why I love honda-tech (kid-honda)
To me looks pretty good.. but i don't think the lil bit of cockyness was at all needed for the qualty of the welds.
ohh and jamie what have you welded to be giving this kind of harsh review???
Old May 5, 2007 | 07:04 AM
kid-honda's Avatar
Default Re: ...And why I love honda-tech (91jdmhatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">To me looks pretty good.. but i don't think the lil bit of cockyness was at all needed for the qualty of the welds.
ohh and jamie what have you welded to be giving this kind of harsh review??? </TD></TR></TABLE>
Auto body diploma with a welding couse, a diploma in welding/bluprint and fabrication and a auto welding certification.
But your right, now that I read it it does look harsh as I gave no reasoning, I will change that but I did say he is doing good for a starter, and definetly great for not having a one on one teacher. I am no tig pro as most of my welding experience is SMAW(mostly 6010, all positions 1/8 inch to 1 inch and pipe) and GMAW (both solid and flux, all positions, same sizes no pipe), In GTAW I have done in all positions but over head, steel, stainless and some positions alluminium and vary minor GTAW with pulse. but next fall I am going back on my own time to get a couple of tig certifications. One being 2 inch pipe.
So as before good effort and when I first started I had the same problems Sometimes still do Tig takes so much practice as I still udercut sometimes but that is fixable with a clean up pass, my biggest problem before was "sugaring" the backside with to much heat.
Sorry your thread got a little off track.
Modified by kid-honda at 10:16 AM 5/5/2007
Modified by kid-honda at 10:21 AM 5/5/2007
Old May 6, 2007 | 04:46 PM
DESTROYER's Avatar
Thanks alot for the tips and insight guys. I apologize for maybe coming off as a little cocky, I by no means am, however I am proud of my accomplishments thus far. Get to know me, you'll know I'm a very humble person.
My faults were all called out, which goes to show how much experience you guys really do have!
Now one issue I had with the 304 pipe, was when I backpurged, it still had some sugar that formed on the backside! I tape off one end with aluminum tape and punch a pencil-width hole in it, block off the other end with a rubber fitting thingy (home depot pipe cap) with a hole in it for the argon line, and ran 3-4cfm into it for 2 minutes before I even started welding, yet sugar still formed. What did I do wrong?
Jimmy
Old May 7, 2007 | 04:05 AM
Argon is heavier than air. It will fall through any gaps in your fitup if you don't seal it up while you are welding. It's early and I'm way to lazy to type this all out. There was a thread by Weirtech about backpurging and we discussed all this in length. It should answer any and all questions you have.
spAdam
Apr 22, 2013 07:29 AM
Ashura*EK9
Oct 7, 2007 07:20 AM
qwk db8
Sep 25, 2007 08:01 AM
socalef9
11
Sep 3, 2005 09:18 AM
