hooking up aem wideband, need help please.
I see where the wires go in the instruction manual but im a little confused with the white and blue wires. white says 0-5V output which i have to my headlights accesory fuse?? and the Blue says SERIAL OUTPUT which i have no idea where that one goes or what it does. Thank you....
The white one is to jumper into your ECU if you don't have a stock sensor anymore and the blue one is for datalogging I believe. Either way, if you still have your stock o2, you don't need to use either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing »</TD></TR><TR><TD CLASS="quote">The white one is to jumper into your ECU if you don't have a stock sensor anymore and the blue one is for datalogging I believe. Either way, if you still have your stock o2, you don't need to use either.</TD></TR></TABLE>
+1
+1
Laojoeturbo
Jan 12, 2010 10:21 PM
trooper0641
40
May 11, 2004 09:38 AM
trooper0641
May 2, 2004 10:21 AM
