need help with factory deck removal 2002 civic
well to cover my a** if you remove a factory radio you will need a code to make it work in another veh or your own after power has been removed.. now that said the part where the cig lighter should be that peice pulls out and then two screws at the bottom then the hole cluster ac and vents and all pulls out of the dash be carful not to nick the trim around the bezel and its not easy to pull out so if you dont feal like you can do it without messing somting up thn pay someone beter to pay to get it done then to get it fixed
hope this helped
hope this helped
JackRabbit
Nov 7, 2008 11:33 AM
D50boy
Apr 3, 2005 01:23 PM
