NEED INFO ON DOHC ZC TRANNY?
Old May 2, 2007 | 06:52 PM
slightly funked's Avatar
Default NEED INFO ON DOHC ZC TRANNY?
I can't find anything about the ZC tranny on a D16Z6. What I need to know is what axles can I use. I swapped a D16Z6 into my 91 CRX SI and I don't know if I can put the z6 axles into the ZC tranny. If someone could hook me up with a link or info that would be appreciated. Thanks
Old May 2, 2007 | 06:55 PM
90 Si Hatch's Avatar
Default Re: NEED INFO ON DOHC ZC TRANNY? (slightly funked)
SEARCH
Old May 2, 2007 | 06:57 PM
Default Re: NEED INFO ON DOHC ZC TRANNY? (90 Si Hatch)
Seem to find all sorts of info but cant find anything about the axles
Old May 2, 2007 | 08:09 PM
AZTEKEF9's Avatar
search....
but i'm in a good mood so i'll help u......i got the same set up on my car.....z6 motor, zc DOHC tranny, z6 clutch and flywheel, .........mmm missing something.......o yea 90-91 integra axels non abs....
Old May 3, 2007 | 05:31 AM
Default Re: NEED INFO ON DOHC ZC TRANNY? (AZTEKEF9)
thank you
Old May 3, 2007 | 05:36 AM
K2e2vin's Avatar
Swap the Si final drive in your transmission and use the stock axles
3.88->4.25
Old May 3, 2007 | 07:18 AM
slywfbpsi's Avatar
Default Re: (K2e2vin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2e2vin &raquo;</TD></TR><TR><TD CLASS="quote">Swap the Si final drive in your transmission and use the stock axles
3.88-&gt;4.25</TD></TR></TABLE>swapping the final drive has nothing to do with your axles. The zc tranny has an half shaft which depicts what axles are needed.
Old May 3, 2007 | 08:09 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">swapping the final drive has nothing to do with your axles. The zc tranny has an half shaft which depicts what axles are needed.</TD></TR></TABLE>
Right, the differential does
You will need a ZC intermediate shaft and 90-93 Integra non-ABS axles.
Old May 3, 2007 | 08:16 AM
K2e2vin's Avatar
Think again; when you swap the Si final drive; you're swapping the differential too(unless you like to do everything the hard way). The differential has the hubs for the axles.
Old May 3, 2007 | 08:18 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2e2vin &raquo;</TD></TR><TR><TD CLASS="quote">Think again; when you swap the Si final drive; you're swapping the differential too(unless you like to do everything the hard way). The differential has the hubs for the axles.</TD></TR></TABLE>
When you put it like that, you are absolutely correct sir
Old Oct 23, 2007 | 08:15 AM
Aquafina's Avatar
Default Re: (wiZCo)
You're making it harder if you swap the diff over. Unless you're just lazy and don't care to reshim it.
Just a tip for anyone that finds this when searching like I just did.
Old Oct 23, 2007 | 08:54 AM
jdm_titan's Avatar
Default Re: (Aquafina)
WHAT?? you have to reshim it?? man thanks for the update.
Old Oct 23, 2007 | 08:59 AM
Aquafina's Avatar
Default Re: (jdm_titan)
Maybe. You need to check the clearance ANYTIME you put in a diff other than the one that came in the trans. Even if it is out of the same trans (ex. 93 EX diff into a 93 EX trans). Might not need to reshim, then again you might. This is standard maintenance though when rebuilding a trans.
teal91
Nov 26, 2008 07:44 AM
Spazius
Jun 16, 2007 02:03 PM
hondacivic90zc
Apr 8, 2007 07:54 AM
SwissChEz82
21
Nov 16, 2004 06:24 PM
Aphrodavid
Nov 6, 2002 08:34 PM
