A little Hondata and Zdyne co-operation?
Old 05-30-2002, 09:40 AM
Speed PHreak's Avatar
Default A little Hondata and Zdyne co-operation?
As most everyone one knows Hondata is a main choice for most OBD-1 boosters in here. Right? For those of you who don't know, Zydne is THE standalone for non-OBD cars. Primarily 88-91 civics. The Zdyne's interface is very similar to that of the Hondata(from what i've heard i've never tuned on a hondata). SO it should be fairly easy to manually swap maps between the 2 correct?
The problem: Zdyne only provides base tunes for the D16A6, B16A, and ZC engines. No base tunes for the B18A/B are provided, tho zdyne will plug directly into a 90-91 LS.......In other words most of us LS hybrid guys or 90-91 LS guys are in the dark where base maps are concerned. We've got to 2 choices, fumble around with on of the other base maps or spend time on a dyno.
What i'm proposing to do is build a base map for an LS engine, from the base maps provided or tuned on a Hondata.
Does anyone know how I may be able to get ahold of the base timing and fueling curves for a Hondata LS tune? Perhaps some of my fellow H-T boosters woulf be will to provied some screen shots of the Hondata ROM software in action?
Please any help would be most apprecited by myself and many others.
~steven
Old 05-30-2002, 10:26 AM
Default Re: A little Hondata and Zdyne co-operation? (Speed PHreak)
The board is moving fast today, ^ bump
Old 05-30-2002, 11:47 AM
Honda Hick's Avatar
BUMP cuz this would be some real helpful info. Damn Zdyne can't make a map for B18s....
Old 05-30-2002, 12:01 PM
93LSivic's Avatar
I got a couple of base LS maps. But I dont know if they are good ones. Hit up racerxadam. He has the one that Sqt sent me on his hardrive--its the one thats currently running my hondata.
Old 05-30-2002, 12:57 PM
*Boostwerks*'s Avatar
Default Re: A little Hondata and Zdyne co-operation? (Honda Hick)
I'm sure there are many people who have B18 map's with a Zdyne.
I personaly know someone with B20/B18C head using a Zdyne. I'll talk to him, and see what he is using.
Old 05-30-2002, 01:39 PM
sgT
sgT's Avatar
Default Re: A little Hondata and Zdyne co-operation? (93LSivic)
looking at the zdyne program, it looks as though converting will take some time.
The zdyne shows fuel in injector pulsewidth, whereas hondata shows a numeric
value which doesnt look like it will be easily convertable.
Am I right in seeing that there is one map for both cams as opposed to one map
for each cam?
Old 05-30-2002, 02:29 PM
Armaan's Avatar
Default Re: A little Hondata and Zdyne co-operation? (sgT)
Can't you use the Hondata on a 1991 Integra? You will need the P74 ECM and the harness....right?
Old 05-30-2002, 02:31 PM
dustin's Avatar
Default Re: A little Hondata and Zdyne co-operation? (2.0L Turbo)
91 integra has an obd0 harness. You'd need an obd0->obd1 harness, an obd1 distributor, and some wiring to make the 1wire o2 sensor work right.
Old 05-30-2002, 02:36 PM
Hondata's Avatar
There are some fundimental differences.
Hondata systems all run dual maps for VTEC. Zdyne has only one.
The axes - load and RPM will have different steps. Ignition would probably be OK providing base timing is similar.
It would be faster to dyno tune.
Doug
Old 05-30-2002, 02:40 PM
sgT
sgT's Avatar
Default Re: A little Hondata and Zdyne co-operation? (dustin)
dustin:you would convert to 4 wire o2 sensor.
doug: yeah, i was thinking the same thing
Armaan's Avatar
Default Re: A little Hondata and Zdyne co-operation? (Hondata)
Doug, is that all I need to run the Hondata with the OBD-0?
Old 05-30-2002, 02:57 PM
racerxadam's Avatar
you have . let me know if that helps or if it doesn't work
Old 05-30-2002, 03:06 PM
dustin's Avatar
I can't see why just running the 1 wire to the ECU would not work, as long as you ran a resistor between the heater wires to avoil a CEL.
Old 05-30-2002, 03:12 PM
sgT
sgT's Avatar
i spose it would, but the ecu might wonder why its taking so long for the o2 to
warm up. or it might not.... <shrug>
Old 05-30-2002, 03:27 PM
dustin's Avatar
Hehe, I don't think it's doing much with O2 feedback at that point (cold start). But alas, this is only conjecture..
Old 05-30-2002, 03:51 PM
New User
Xerxes's Avatar
for each cam?
there's an option in the romeditor to view estimated injector pulse width, so you could use this to try to translate from a hondata base map to a zdyne one. it would probably have to all be done by hand, but it shouldn't be that hard, just time consuming (2-3+ hours i'd guess)
-Xerxes
Old 05-30-2002, 09:37 PM
Thanx for all the support guys, I've gotten ahold of a Hondata map. I'm in the process of adapting the Igintion map over. It's kind of a tidious cell by cell process, but it'll work. The hard part will be converting fueling over. Personally I like the Zdyne pulsewidth system better than Hondata's. I'll post up in the morning when i'm done
Thanx much the Racerxadam for the .csv file.
Damn it's late
[Modified by Speed PHreak, 1:38 AM 5/31/2002]
Old 05-31-2002, 02:03 AM
marklamond's Avatar
Feel free to shoot me down but can't you use a OBD0 PW0-000 ecu converted to Hondata in your car?
Be interesting to see the results anyway - you could make a spreadsheet to convert between the two perhaps?
IMHO I'd rather have a Hondata with datalogging over a Zdyne any day, tuning a Zdyne is like riding a bike without a saddle (who's not happy with Zdyne at the moment).
Old 05-31-2002, 05:09 AM
Default Re: A little Hondata and Zdyne co-operation? (marklamond)
Perhaps, i'm not sure about Hondata. For the money I went with Zdyne. I've been pleased with it. Datalogging would be very nice and I heard that Zdyne was working on it . I'll admit tuning the Zdyne is somewhat a vague process without a dyno. I'm prolly going to be getting one of those DYI wideband deals.
I'm not sure, but I think you have to convert to OBD-1 electronics to run the the converted PW0/PR3 ECU's?
Old 05-31-2002, 07:55 AM
New User
BeeT's Avatar
I'm sorry but I'm trying to wrap my head around this. If I get a Zdyne (IF cuz I can never get a hold of the guy.. ever.. I've left him 3 messages) for my B18A, I will actually need to enter everything from scratch? There is not starting point that I can work with? Or am I reading this wrong?
Old 05-31-2002, 08:09 AM
Default Re: A little Hondata and Zdyne co-operation? (BeeT)
Correct Zdyne does not come with a standard tune for the LS engine.
However, I've got a few tunes based around different engines for the LS. The one that i've using now is based off a ZC. I've got a few based on the D16. But I can hook you up if you need. They all work faily well, but I want the real deal. Thats why I started this thread. The newer LS ECU's supposedly had a bit better fuel/spark mapping. Hopefully I'll be done by the end of the day with this Hondata conversion. I'm having to do it all by hand so it's taking a bit.
UPADATE: Spark maps have been converted over. The fuel is taking a bit b/c i'm having to find a way to convert that blasted numbering system over to a usable format.....ugh math.
Old 05-31-2002, 08:16 AM
New User
BeeT's Avatar
Well, Good luck! I'll have to keep in contact with you when I get my zdyne.. or if I get my zdyne rather... hahaha..
Old 05-31-2002, 01:22 PM
UPDATE: After a long tedious session of number/formula crunching I believe I have achieved 90% completion!
SPARK -- DONE
FUEL -- DONE
All that is left is getting the idle values correct and then the tune should be done! I'm on my way home to test it out. Hope the better part of the workday that I spent on it will pay off!
Be back in a few hours guys!
Old 05-31-2002, 09:36 PM
New User
SiR Kid's Avatar
Howd it work man? I'm curious!
Old 05-31-2002, 11:29 PM
New User
jetli6969's Avatar
man you sure do work hard to get things done right ... to you
Quick Reply: A little Hondata and Zdyne co-operation?
