tranny shifter rod
Old May 2, 2007 | 11:56 AM
rsr001's Avatar
Default tranny shifter rod
Hello I was gonna change my tranny oil the other day,when I got under the car I saw oil residue(not sure on the spelling) around where the shifter rod enters the tranny.how would I fix this with out taking this to a shop? does anyone here have a HOW TO or a DIY write up on this? I did a search and saw a post but it was not detailed on how to fix it.last question is this big enough problem that i should change it out asap?
Old May 2, 2007 | 12:03 PM
rsr001's Avatar
Default Re: tranny shifter rod (rsr001)
sorry just click on the pix to make them big...
Old May 2, 2007 | 12:45 PM
db8sirg's Avatar
easy fix. replace the shift rod seal. remove the shift linkage and pop out the seal and tap in the new one. only thing that might give you a problem is the spring pin holding the linkage to the rod.
Old May 2, 2007 | 01:02 PM
rsr001's Avatar
Default Re: tranny shifter rod (db8sirg)
thanx my man. last question am i safe to race my car at the local track before i fix it? or should i fix asap?
Old May 2, 2007 | 01:13 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsr001 &raquo;</TD></TR><TR><TD CLASS="quote">thanx my man. last question am i safe to race my car at the local track before i fix it? or should i fix asap?</TD></TR></TABLE>
You are safe, as long as enough fluid didn't leak out to make your tranny be on a low level. Looks like a small leak anyway.
Old May 2, 2007 | 02:34 PM
Gearspeed-Performance's Avatar
Default Re: tranny shifter rod (neo_)
Just fix it...Don't put any oil down on the track Good luck!
Old May 2, 2007 | 10:36 PM
rsr001's Avatar
Default Re: tranny shifter rod (GearSpeedEF7)
yea im gonna fix it , i already orderd the seal should be in soon thanx
91grape
Sep 13, 2012 04:18 PM
hondazccivic
Aug 4, 2008 06:11 PM
EG2Driver
Jun 7, 2006 02:49 PM
Shane54
Oct 11, 2003 08:53 PM
db8sirg
Sep 8, 2003 07:05 PM
