quick question about b series headers
Old May 2, 2007 | 09:54 AM
fitbmx86's Avatar
Default quick question about b series headers
are gsr and ls heads the same pattern for exhaust manifolds, cause i find a lot of headers that say either for ls or gsr and a lot of them are 4-2-1 for the ls but i want a 4-1 and i usually only see them listed for gsrs, thanks!
Old May 2, 2007 | 09:58 AM
Malakai's Avatar
they are diff i believe.
Old May 2, 2007 | 10:04 AM
THC07's Avatar
Default Re: quick question about b series headers (fitbmx86)
B series are the same, I believe.
4-1 header its header, theres only one.
Old May 2, 2007 | 10:13 AM
fitbmx86's Avatar
haha i always make that mistake. thanks for the help
Old May 2, 2007 | 10:14 AM
Padawan's Avatar
Darth ModerVader
The bolt pattern on the heads is exactly the same. However, the overall length of the LS header is different than that of the '94-'99 GS-R. What header is it that you're looking at?
Old May 2, 2007 | 10:17 AM
Mashimaro's Avatar
Default Re: quick question about b series headers (Padawan)
if i recall, i belive the GSR also has a difference in length (on the bottom part just before the cat begins) on certain years, i'm not sure which was shorter or longer though...
Old May 2, 2007 | 10:22 AM
Padawan's Avatar
Darth ModerVader
Default Re: quick question about b series headers (Mashimaro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mashimaro &raquo;</TD></TR><TR><TD CLASS="quote">if i recall, i belive the GSR also has a difference in length (on the bottom part just before the cat begins) on certain years, i'm not sure which was shorter or longer though...</TD></TR></TABLE>
That's what I wrote above.
The '94-'99 GS-R is approximately 4" - 4.5" shorter than the LS, ITR or '00-'01 GS-R.
Old May 2, 2007 | 10:34 AM
Mashimaro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
The '94-'99 GS-R is approximately 4" - 4.5" shorter than the LS, ITR or '00-'01 GS-R. </TD></TR></TABLE>
lol, sorry dood, i thought you were referring to deck-height length. i must have mis-interpretted.
Old May 2, 2007 | 10:42 AM
toojy's Avatar
if you gotten the short header
you can always get an extension cat or whatever its call from the 92-93 integra
Old May 2, 2007 | 10:45 AM
SkoundrelUSA's Avatar
cute little bastard
Either way the header will still fit. Just don't attempt a header made for a B16
Old May 2, 2007 | 11:57 AM
fitbmx86's Avatar
well either way it is going to have to be bolted onto a 95 civic 2 dr so im sure some modifying will be done. whats my best bet then? its a LS motor
Old May 2, 2007 | 12:06 PM
Padawan's Avatar
Darth ModerVader
Default Re: (fitbmx86)
What's your budget?
Old May 2, 2007 | 12:11 PM
fitbmx86's Avatar
im going with cheap ones right now its basically just so i can get rid of the shitty welded one i have right now, im not spending a lot of money on it because im going turbo evetualy and would rather get a better turbo manifold later on.
Old May 2, 2007 | 12:13 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fitbmx86 &raquo;</TD></TR><TR><TD CLASS="quote">im going with cheap ones right now its basically just so i can get rid of the shitty welded one i have right now, im not spending a lot of money on it because im going turbo evetualy and would rather get a better turbo manifold later on.</TD></TR></TABLE>
IMO just save your money then and wait
Old May 2, 2007 | 12:14 PM
fitbmx86's Avatar
i can't this leak is pretty bad and im not sure when i will be able to turbo the car, i don;t mind spending 100 on a cheap generic brand but i need to get it fixed
nickhans
Jun 9, 2008 09:23 PM
bomber19
Jan 7, 2008 08:41 PM
Contender25
Jun 12, 2005 11:31 PM
tegasaurus
Jan 13, 2004 07:24 PM
ramdog
Nov 13, 2002 03:18 PM
