Suspension Thread (contains Pictures and Specs)
Old May 2, 2007 | 09:04 AM
TouringAccord's Avatar
H-T Order of Merit
Default Suspension Thread (contains Pictures and Specs)
This thread is for suspension setups only. All I want to see in here is members listing their current suspension setup with a picture or two to show the drop. This is not a thread for discussions or to ask questions. If you have a comment for a member, IM them, if you have a question that isn't answered by this thread or by searching (recent, archive, FAQ, Guide to Basic Accords) then make a new thread. This is simply here for a reference. Points will be deducted from those who repeatedly do not follow the rules and if people continue to not follow the rules, this thread will be locked.
When you post, I'd like the follow things to be included...
Year/Model/Trim:
Suspension: (List manufacturer and product of whatever it is you have installed... springs, struts, coilover sleeves, full coilovers, sway bars, camber kits, etc.)
Specs: (If you have adjustable struts list what you have them set to, if you have coilovers specify how much you've lowered it, etc.)
Rim/Tire: (List what rim you have as well as the diameter, the width and the offset. Also list what tire you have as well as the size and tire pressure.)
Alignment Specs: (List your alignment specs, if you have them, so people can see how certain suspension setups will affect their alignment. Will also help people to decide if they'll want a camber kit or not.)
Brief Description of How the Car Rides: (Give a brief description of the cars ride and how it handles... bouncy, smooth, harsh, etc.)
Pictures: (Post a picture or two that gives a good view of the drop. Don't post 3-6 general pictures of your car, there is a thread for that, keep the picture(s) specific.)
Thats all I can think of, if I've missed something or if anyone thinks of something else that they feel should be added to the list, IM me and we can discuss it being added.
Old May 2, 2007 | 02:11 PM
Andryzzle's Avatar
Default Re: Suspension Thread (TouringAccord)
-1994 EX Sedan
-Tanabe Sustec S-OC Type II full coilovers. the front is about 1-1.5 inches from the bottom of the threads and the back is about 2 from the bottom (estimated)
-17x7.5 Rota subzero i think its 45mm offset
-Yokohama AVS ES-100 205/45/R17 at recommended pressure
-Ride is amazing, stiff and sticks to the road but not uncomfortable.
Old May 2, 2007 | 04:44 PM
Optical Toxin's Avatar
Default Re: Suspension Thread (Andryzzle)
Year/Model/Trim: 96 Accord EX
Suspension: Skunk2 Racing Springs, Tokico Illumina struts, Ingalls, poly-urethane 3 degree anchor and bolt kit for the front, washers in the rear, Megan FU strut bar
Specs: Illuminas are currently set on 3. 1 is the softest, 5 is the stiffest. i had it on 5 for a couple weeks, but it was just uncomfortable. yes, the handling was great, but it wan't practical.
Rim/Tire: Stock, 195/60/15 i think. 33 psi in the front, 35 psi in the rear.
Alignment Specs: -1.2 on the front, with my camber kit fully extended. without the kit, it would be -4.2. the back is -1 and that's with 5 washers per 10x1.25x50mm bolt
Brief Description of How the Car Rides: car rides great, really smooth on the 3rd setting. on 5, it was great for handling, but the ride was just too bumpy for me.
before the tint and rear splash-guards:
Modified by Optical Toxin at 9:55 PM 5/9/2007
Old May 2, 2007 | 04:46 PM
gosu08's Avatar
Year/Model/Trim: 1994 Honda Accord EX
Suspension: KYB GR-2 with H&R Sportline in the front and Eibach Prokit in the rear. The front drop is 1.75in and the back is 1.2
Rim: 15 x 5.5 OEM Honda EX Rims not sure of stock offset.
Tires:Yokohama Avid Touring 195/60/R15. Tire pressure is set at 32psi all around
Alignment Specs: Ingalls camber kit front and Ingalls Smart Arms in the back. My camber is now about -.2 degrees all around. Without the kit i had -2.8 and -2.3 degrees camber each side on the front and about -1.2 and -1.5 on the back.
Brief Description of How the Car Rides: The car rides just like stock maybe a little bit stiffer. I am happy with the way that it rides and sits, not too bouncy and not too stiff. I know its an odd setup but it sits nice. I have about a 5.5in gap from my front lip to the ground. One finger gap in the front and two finger gap in the back.
Old May 2, 2007 | 08:04 PM
lowered94accord's Avatar
Default Re: Suspension Thread (gosu08)
-1994 Honda Accord EX
-KYB AGX Adjustable shocks, Tenzo Racing Springs
-2.5" in the front and 2.2" in the rear I believe
-15" honda factory wheels, 195/60/R15
-Rides and handles awesome..I have the adjustable KYB's set to the hardest setting both front and rear..i believe its 8 in the back and 4 in the front..I dont have any really good pics of the drop
Old Nov 14, 2007 | 08:28 PM
oem_certified_accord's Avatar
Default Re: Suspension Thread (professorman)
94 LX
Intrax Springs: 1.7 Drop Front / 1.6 Rear
OEM shocks
18x7.5 icw osaka
215/35/18 Fr. & 225/40/18 Rear
rides like a dog sled, front shocks blown.
Old Nov 16, 2007 | 11:20 PM
hurleyint's Avatar
1995 Accord LX
Suspension: Omni Power Street (F=10k R=8k) full coilovers, front and rear strut bar, rear lower tie bar, EX front sway bar, ST rear sway bar, front and rear camber adj. kit, misc. poly. bushings.
Specs: Lowered 3+ inches
Rim/Tire: Prelude wheels with Kumho SPT 205/50/15
Alignment Specs: Front camber -1 deg Rear camber -.5 Toe set at 0 deg.
Brief Description of How the Car Rides: Smooth on good roads, bumpy on bad roads. Stiff, but not too crazy for a daily, yet still track capable.
Pictures:
edit
Modified by hurleyint at 1:41 AM 8/16/2008
Old Nov 17, 2007 | 07:15 PM
NGUSPEED's Avatar
Year/Model/Trim: 1996 Accord LX
Suspension: Progress Springs & Tokico HP's
Specs: 2.0 F, 2.0 R
Rim/Tire: OEM 98-99 Accord EX Sedan 5 Spoke Swirlies, 185/60/15 Yokohoma A430 Tires
Alignment Specs: N/A
Brief Description of How the Car Rides: Car rides really smooth. Almost like stock. I believe that is due to the shocks I have and tire profile. I dont like how smooth it is.
Pictures:
Old Nov 17, 2007 | 09:09 PM
hahaha38's Avatar
Suspension:Ground controls and kyb agx 2 in fornt 6 in the back
Specs: Low maybe 5ish??
Rim/Tire: 18s 215/35/18
Alignment Specs: -1.50 front -1.00 rear
Brief Description of How the Car Rides: The car actually rides like crap right now due to the drop.But it looks cool.Reason for the ride quality is because my upper control arm is sitting on the frame.
Pictures:
Old Nov 18, 2007 | 06:33 AM
accordselux's Avatar
Me Gusta History
Year/Model/Trim:2000 Accord SE
Suspension: Tokico Illuminas, Neuspeed Sport springs (1.8 F 1.7 R), front strut bar, Acura TL type S rear sway.
Specs: Illumina fronts set to 3, rears 4.
Rim/Tire: 17x7.5 Falken Hanabi riding on 215/50/17 Bridgestone Potenza G 009, recommended air pressure.
Alignment Specs: Within factory alignment specs
Brief Description of How the Car Rides: Not very bouncy, but you do feel every crack in the road. Generally uncomfortable for a DD if you aren't willing to suffer for it. Personally after 5 years of owning my car I'd want to put it back to stock instead of being so low and uncomfortable. Not enough shock travel due to the lowering, and it scrapes on steep inclines.
Old Nov 18, 2007 | 08:40 AM
d112crzy's Avatar
Year/Model/Trim: 1993 LX CB7
Suspension: KYB AGX(2f/5r), Tein S-tech springs
Rim/Tire: 4th gen vtec prelude wheels on 205/55/15. Picture shows Falken Zeix 512's, now riding on Hankook 601's
Alignment Specs: I've never had a problem with visible-to-the-eye camber, until I took out my bump stops. Taking out the bumpstops on the front lowered my car about 1/4''.
Brief Description of How the Car Rides: The ride is nice and smooth. A bit harsher than stock over crappy roads, but is smooth as stock everywhere else.
Performance wise, it sucks, imo. The car IS lower and does handle better than stock, but the springs are WAY to soft for some serious twisties action. Body roll>this car
The front end sits a bit lower now, ever since I took out the bump stops.
Old Nov 24, 2007 | 09:33 AM
TheMuffinMan's Avatar
He knows where you live!
Suspension: Koni Yellows w/ Ground-Controls
Specs: Konis: Stiffest in front (3 turns) Middle in rear (2 turns) GC's with about half thread left all the way around
Rim/Tire: 96 ITR Wheels w/ 205/50/15 Hankooks 42psi front , 40 in rear
Alignment Specs: F camber kits, roughly -3o camber in front, probably 1-2o in rear, toe has been 0'd out
Brief Description of How the Car Rides: Stiff settings however not bouncy, pretty good all around
Pictures:
Good sideshot of where it sits now
Old Aug 7, 2008 | 06:44 PM
bopbop93030's Avatar
Default Re: Suspension Thread (TheMuffinMan)
Year/Model/Trim: 95 Accord EX
Suspension: Tokico Illuminas/ H&R Sport
Specs: Tokicos setting: 2 in front, 1 rear good for daily driving. 1 finger gap front and rear.
Rim/Tire: Kyowa Racing KR595 with 205/45/17 Yokohama S-Drives 35 psi all around, still experimenting
Alignment Specs: Ingalls camber kit. I do not have specific measuring but 0 toe
Brief Description of How the Car Rides: Tolerable, not to bouncy.
Modified by bopbop93030 at 7:49 PM 8/7/2008
Modified by bopbop93030 at 7:53 PM 8/7/2008
Old Nov 16, 2008 | 01:31 PM
Bozo_JDM's Avatar
Default Re: Suspension Thread (citizen21)
1996 Accord EX
15" stock rims pirelli tires 195/60/R15
toe is 0
the ride is stiff and it doesnt scrape as much as i thought after we lifted the exghaust with shorter bushings
Old Dec 3, 2008 | 01:17 AM
huskyl3oi's Avatar
Year/Model/Trim: 94 accord ex sedan
Suspension: H&R Street Perf. Coil Over
Specs: 2.5 front 2 rear.
Rim/Tire: Vesta Ein khan II 17x8 +30/215-40 front 17x9 +38/215-45 stretched rear
rear tires rubs when turning.
Alignment Specs: have spacer in the rear. have good contact.
Brief Description of How the Car Rides: i love the ride. soft smooth handles like a champ. dont know if my rear shocks or spring are worn but rear droops with a passenger.
Pictures:
Old Dec 6, 2008 | 04:56 PM
sfcd5's Avatar
1996 accord ex cd7
Ground Controls with yellow Koni
2.2cl rims 205/50/16
handles great, but i live in San Francisco an the road
are pretty uneven with tons of pot holes. sometimes the ride can be
really unbearable.
Old Dec 7, 2008 | 10:58 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Year/Model/Trim: 95 EX.
Suspension: Koni adjustable struts with neuspeed sport springs. koni struts were set to lowest on spring perch. Fronts are adjusted 3/4 of the way to stiffest. Rears are 1/2 way.
Rim/Tire: RacingHart Type C 18X8 with a 42mm offset.
Pirelli 225 40 18 tires.
Alignment Specs: Ingalls kit up front set to max out. Washers at back. sorry no specs.
Brief Description of How the Car Rides: It rides almost like stock. Nice firm but not punishing at all.
Pictures:
Old Oct 31, 2009 | 04:59 PM
awdpwr's Avatar
Default Re: Suspension Thread (contains Pictures and Specs)
bringing this back up.....im trying to figure out what i should go with. let see some more pics of the 98-03 body style.
Old Nov 23, 2009 | 01:38 PM
02 accord's Avatar
2002 Accord SE, 5 speed.
Eibach sportlines with Koni yellows.
2 inch drop front and rear, 2/1 finger gap F/R.
-0.6L/-0.5R camber up front, -2L/-1.4R in the back; 0 toe all around.
Stock SE 15x6 inch rims with 205/60-15 Yokohama ES100s.
Old Nov 23, 2009 | 03:39 PM
craziicd5's Avatar
1997 Honda accord 5spd
dropped on function and form type 1 coilovers
dont know how low but 1 finger gap front 2 finger gap rear
no camber kit on front and rear camber at .5
stock ex rims with 205/50/15
rides a little rough since i increased the spring rate, but handles alot better
Old Jul 20, 2010 | 10:01 AM
NWCG3's Avatar
:2001 Accord 2dr SOHC
:Nex SS Full Coilovers
:Federal SuperSteel 595's 205/50/17 on unknown wheels they are 7x7.5. Got them on CL lol ftw.
:Fully lowered in front 3.5 in. In rear 4 in. Not sure on camber in rear, its very small. No camber in the front.
: They only adjust height and spring stiffness, no dampner setting. With that said, I have the springs set to super stiff all the way round. Rides bouncy and harsh on rough freeway, but on smooth pavement it glides but still you feel every crack. Im going to soften the fronts a bit to help with the front "up and down" on those big freeway dips.
Honestly, for $400 used, they ride pretty good, corners are crisp but the bouncy sway in the front kinda kills the whole vibe of tight turns. You decide...Im switching to AMR Engineering Full Coilovers. Only $1450 son FTW!!
Old Jul 21, 2010 | 05:42 AM
ooopseyesharted's Avatar
1996 Accord EX Wagon
Suspension: Kyb Agx adjustables with neuspeed springs
Specs: They are 4 ways and they are set on the second firmest setting
Rim/Tire: 17x7 (offset not unknown) Stamford wheels with Kumho tires
Alignment Specs: NA
Brief Description of How the Car Rides: Car is great. Just a little low for cleveland streets
Old Mar 26, 2012 | 05:53 AM
h22a2JZGTE's Avatar
Suspension: tokico hp blue struts w/ tokico red lowering springs
Rim/Tire: stock 15s wrapped in michelin pilot exalto a/s 4 season sport tires
Alignment Specs: washers in rear
Brief Description of How the Car Rides: its firm, but its not low enough for me, really wish i wouldev bought some tein basics or some tanabe sustecs, but my suspension is good for the harsh minnesnowda roads
Old Mar 26, 2012 | 10:59 AM
CD5B2's Avatar
1997 LX
Koni Orange (Str.t) w/ Eibach Pro Kit
195/55 Falken ZIEX 912; 15" Enkei PKR
It rode a little bouncy at first, but after getting polyurethane spring isolators I noticed a smoother ride. I also had to replace the sway bar frame bushings and links. Handles much better then stock for an entry level drop.
http://s46.photobucket.com/albums/f1...t=P1060952.jpg
Old Jun 23, 2015 | 05:58 PM
onunezp's Avatar
Can you please tell me where did you get your tailights?
Pictures:
