1990 Integra subframe into 1988 CRX. Will this work????
Old May 2, 2007 | 05:44 AM
driveahonda's Avatar
Default 1990 Integra subframe into 1988 CRX. Will this work????
My CRX's subframe is bent. I have a 90 integra that i am currently parting out.
Can I take the Integras subframe off and put it on my crx???
Any responses will help.
Thanks, nick
Old May 2, 2007 | 12:29 PM
any help
Old May 2, 2007 | 02:10 PM
hondacrxturboSi's Avatar
Default Re: 1990 Integra subframe into 1988 CRX. Will this work???? (driveahonda)
why you askin people here why dont you just l0ok under the car and see if they l0ok the same and bolts line up and rear motor mount is in the same place and all that ****
Old May 2, 2007 | 02:30 PM
Donkey85's Avatar
Default Re: 1990 Integra subframe into 1988 CRX. Will this work???? (hondacrxturboSi)
..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxturboSi &raquo;</TD></TR><TR><TD CLASS="quote">why you askin people here why dont you just l0ok under the car and see if they l0ok the same and bolts line up and rear motor mount is in the same place and all that **** </TD></TR></TABLE>
because maybe he wans to know if somebody has done it already and has any tips to offer... unlike ur worthless post
Old May 2, 2007 | 03:41 PM
haha, you're an idiot.
Lets see if you can smarten up and make your 18th post on hondatech a little more intelligent.
But yeah, if any one has done this before, please let me know if it worked or not. If I have to be the 1st one on here to try it I will, but i would like some input first.
Old May 3, 2007 | 06:13 AM
TTT
Old May 3, 2007 | 10:02 AM
wiZCo's Avatar
Stouts 'n' Scotch
Try matching OEM part numbers (no I'm not gonna do it fer ya ). If I had to guess though I'm going to go with no.
Old May 3, 2007 | 11:24 AM
they dont match. But the integra has the additional bar goin from the front crossmember to the rear crossmember, so the part number would not be the same even if it did bolt on perfect.
Old May 3, 2007 | 11:29 AM
wiZCo's Avatar
Stouts 'n' Scotch
Well, there's only one way to find out then, and it involves a cutoff wheel and a torch .
Old May 3, 2007 | 11:34 AM
RockinthEFhatch's Avatar
We hate you here at Honda-Tech. Return to SHO.
Default Re: (wiZCo)
Ha, it may come down to that.
It is raining in my part of the world right now, so this project is on hold until this weather blows over.
Old May 3, 2007 | 11:36 AM
Default Re: (driveahonda)
I think you could make it work, it'd require a lot of additional work though. Might be worth it to find a CRX shell...
Old May 3, 2007 | 02:03 PM
stmizner's Avatar
i believe it's the same as the crx sir which has a mount location for the b-series. if that doesn't help, try checking the integra manual and comparing bolt locations to the crx.
Old May 3, 2007 | 04:31 PM
anahaevia8's Avatar
Default Re: (stmizner)
Not sure if it's any help, but I have a 90 civc si shell that I need to get rid of for next to nothing...
Dunno if it would bolt up, but if it does and you're interested just lemme know.
Old May 4, 2007 | 11:14 AM
Default Re: (anahaevia8)
I am interested, if you can get me a price on shipping and the part that would be great.
Thanks
Old May 4, 2007 | 02:29 PM
anahaevia8's Avatar
Where are you located first of all...
Old May 4, 2007 | 05:12 PM
good call, 23669
Old May 5, 2007 | 03:39 PM
anahaevia8's Avatar
To be honest, it wouldn't be worth it for you to ship a shell there.
You're better off renting a 2 wheel dolly for like $40 and making the trip to indy if you're serious about it...
Freight would be difficult and expensive, ya know what I'm sayin'?
Lemme know what you think.
If you really want to pay for freight then I'm all for it.
Old May 6, 2007 | 02:41 PM
Actually, I was thought you were only talking about selling the front subframe. But send me some pictures of the shell if you have any, IconTuning@***.net.
Old May 21, 2007 | 11:33 PM
BrakeExpert's Avatar
no one mentioned. Front or rear subframe?
Old May 22, 2007 | 06:23 AM
It was for the front. I ended up fixing the crx subframe though. So the answer is still a mystery.
Old May 22, 2007 | 10:59 AM
mahatma's Avatar
i have '91 civic and '92 integra front crossmembers stacked on top of one another in the trunk of my taurus right now
i'll tell you what, visually they look exactly the same. same length, same mounting hole locations....except the holes in the teg xmember where that middle brace bolts up.
seems to me you could use the integra piece in a civic, but not the other way around.
Old May 22, 2007 | 11:41 AM
Default Re: (mahatma)
Yeah, thats the conclusion I came to as well. I never actually bolted it on though.
JDMASTER EJ8
Mar 26, 2008 02:02 PM
ozrednsx
Jun 1, 2006 07:12 AM
Pearl Crx
May 24, 2005 01:23 PM
Crosser
Apr 19, 2005 05:16 PM
redlinegsr
Sep 22, 2003 11:18 AM
