Honda S2000 Honda S2000
what lowering springs do you guys run on oem shocks and how do you like them?
Old May 1, 2007 | 10:47 PM
DC4R27's Avatar
Default what lowering springs do you guys run on oem shocks and how do you like them?
just like the title says. My friend just bought an s2k and wants to know what springs will be the best match for the oem dampers. thanks.
Old May 2, 2007 | 09:24 PM
Techno Tonis's Avatar
Default Re: what lowering springs do you guys run on oem shocks and how do you like them? (DC4R27)
i run oem's on oem's and the setup is amazing
Old May 3, 2007 | 09:38 AM
s2kdre's Avatar
Default Re: what lowering springs do you guys run on oem shocks and how do you like them? (Techno Tonis)
if u want the oem shocks too last longer, then go with teins of eibachs, and they ride really good, i used to have skunk2 springs but i didnt like them because the rear was too high and didnt match the front, and then i went with apexi exv coilovers.
Old May 3, 2007 | 09:43 AM
Berlinasp1's Avatar
Default Re: what lowering springs do you guys run on oem shocks and how do you like them? (s2kdre)
Ive heard of coil overs popping when turning sometimes, have you experienced that at all?
Old May 3, 2007 | 10:07 AM
m R g S r's Avatar
Default Re: what lowering springs do you guys run on oem shocks and how do you like them? (Berlinasp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Berlinasp1 &raquo;</TD></TR><TR><TD CLASS="quote">Ive heard of coil overs popping when turning sometimes, have you experienced that at all?</TD></TR></TABLE>
yeah they just blow up
Old May 3, 2007 | 01:00 PM
Archibalds_Puppet's Avatar
Default Re: what lowering springs do you guys run on oem shocks and how do you like them? (m R g S r)
Yeah, coilovers are straight line only. If you try to turn the car they will explode like hydraulics on cocain, then your car will fly 100 feet in the air and explode on implact with the ground.
Old May 5, 2007 | 05:16 PM
blueshark's Avatar
techo tonis is right! If you want to lower a S2K use correct aftermarket setups for, though it handles quite well on it's own! Trust mother Honda
tpot90
Mar 24, 2008 11:27 PM
patrickstar
14
Feb 20, 2008 05:45 PM
tpot90
Nov 26, 2007 08:37 PM
5200BB6
Jan 6, 2005 11:58 PM
99 HXagon
Jan 20, 2002 06:03 PM
