95 DX mini me swap problems
Old May 1, 2007 | 08:21 PM
cticknor666's Avatar
Default 95 DX mini me swap problems
Ok, im did this swap for my buddy. Got everything back together an it wont fire up. I cant figure anythign out so if anyone has some pointers or suggestions im all ears. I put a z6 head on it, an swapped in a p28 an wired vtec up an everything. Did the timing/water pump/tensioner ect. Im gettin gas and spark, but yet it doestn fire up. COuld i have messed the timing up. Had the marks lined up, did the straw in the spark plug trick to kinda double check the engine was at TDC. Anyone have any ideas?? After cranking a few times an pulling the plugs their dark black an a few smell of gas.
Old May 1, 2007 | 09:17 PM
Default Re: 95 DX mini me swap problems (cticknor666)
bump
Old May 1, 2007 | 10:28 PM
deadline's Avatar
hard to say but double check wiring...did the z6 come off a running car ?
Old May 3, 2007 | 04:58 PM
yea it did. I switched out ecus today an put back the auto dx ecu that was in the car, its wanting to start its just not. I have spark but i noticed its really weak an not really consistent. Could that be a bad dizzy?
Old May 3, 2007 | 05:54 PM
da_dude's Avatar
Default Re: (cticknor666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cticknor666 &raquo;</TD></TR><TR><TD CLASS="quote">yea it did. I switched out ecus today an put back the auto dx ecu that was in the car, its wanting to start its just not. I have spark but i noticed its really weak an not really consistent. Could that be a bad dizzy?</TD></TR></TABLE>
Maybe your distributor is 180 degree off. When your motor is at TDC, the rotor in the distributor should be at cylinder #1. Take the distributor cap off and turn the motor back to tdc and check to see of the distributor rotor is on cylinder #1. Happen to me once.
Old May 3, 2007 | 06:04 PM
How would i tell if the rotor is on the number 1 cyl?
Old May 3, 2007 | 08:33 PM
da_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cticknor666 &raquo;</TD></TR><TR><TD CLASS="quote">How would i tell if the rotor is on the number 1 cyl?</TD></TR></TABLE>
Here is two picture that I'm taking about. I got these picture for d-series.org. Hopefully he doesn't mind me using his pictures. (IM me if you want them down.)
Here is the picture that show you cylinder #1, #2, #3, and #4.
And here is firing order with the distributor cap off. Notice the rotor on the picture. It is suppose to be on cylinder #1 when the motor is at TDC.
00ejhatch
21
Dec 4, 2013 04:22 AM
94_civic_dx
Jul 17, 2012 07:21 AM
dalebly50
Feb 26, 2012 01:52 AM
TheLastSpartan
Sep 4, 2007 09:16 PM
Kamin
Apr 17, 2003 06:16 PM
