throttle rotor sticking?
Just swapped a y8 intake manifold on my y7.....everything works just fine, except i notice that sometimes the throttle rotor gets stuck sometimes.......if i drive the car and park it for a bit, when i com back out i have to mash on the gas pedal to get it unstuck......i am using my y7 throttle body with the y8 throttle rotor and spring.....i am also using the y8 throttle cable........any suggestions?.....did i tighten the throttle rotor too much?
Mine does this too. Except it does it within 2 seconds of letting off the pedal. Its annoyyinggggg... Except i dont try to fix mine. I just deal with it
There is a little screw that stops the rotor from returning to far this may need to be adjusted. If its out of adjustment or missing the throttle will close to far and stick I have seen this a couple times hope it helps
hondadda
Oct 6, 2007 06:49 AM
ekx4
Jun 1, 2007 10:38 AM
Wazup
Feb 21, 2006 11:26 AM
