spark plugs
Old May 1, 2007 | 11:09 AM
stevescivic's Avatar
Default spark plugs
can someone here please tell me why the spark plugs for the integra type R is so insanely expensive compared to other platinum plugs made by NGK?
I orders a set of 4 from the dealership only to find out that they were chargin $18/plug!
I looked at the plugs and the writing on them is a different color than that of the normal ngk platinums. The writing is in blue and the electrode looks like it also has a nub of platinum on it.
Are these really worth it or can I simply go to Canadian tire and buy a set of NGK G power platinum's for 8.99 a pair?
Thanks
Old May 1, 2007 | 11:11 AM
doood's Avatar
been there done that
Default Re: spark plugs (stevescivic)
different heat ranges maybe? the itr uses a colder plug than a gsr.
Old May 1, 2007 | 11:21 AM
Default Re: spark plugs (doood)
well here is the scenario. As I was taught by a friend of mine all vtec B series motors can interchange plugs. I was actually at honda and I ordered a set of plugs for 00 Civic SiR w/ B16A engine. I called Acura to ask about the plugs for a 96 integra LS with B18B1 and they both use the same plug. I just can't believe how expensive the platinum plug is in comparison to what you can buy at the local automotive supply house.
I guess what I'm really asking is what is the difference between the NGK G power series or even the NGK iridium plugs vs. the honda boxed NGK platinums?
THe only thing I can clearly see is the writing on the insulator is blue and NOT green like most NGK's and that the ground electrode has a flat round spot that looks like a nub of platinum. Could that nub make that much of a difference in the overall plug design and performance/reliability?
I do realize that b/c honda/acura sells the plug that they can charge a premium but when you think about it... I can buy the honda boxed NGK's regular V groove plugs for cheaper than I can at Canadian Tire. The question then comes up, how much markup could there really be on plugs to create that much of a differential in price on their plantinum series?
Can anyone here shed some light on this?
Old May 1, 2007 | 11:32 AM
Sfedai0's Avatar
If you dont mind changing your plugs a bit more frequently, just go with some cheap ngk coppers.
Old May 1, 2007 | 11:36 AM
andyt's Avatar
I would rather buy $1.50 a piece plugs and change them more frequently.
Generally the cost of a spark plug is relative to its expected lifetime.
The more you pay the longer it should last.
After 6 months in my car, all plugs suck. I'd rather spend 8$ than $60+.
Old May 1, 2007 | 12:00 PM
doood's Avatar
http://www.ngksparkplugs.com you can find the info you want there
ScottF
Feb 21, 2010 10:49 AM
Lovemy99Lude
Jan 31, 2009 09:25 PM
jdmitr01
Oct 8, 2004 09:57 PM
ILLICON3000
Sep 20, 2004 07:45 AM
