Solid CEL and ECU Code 9 CPY Sensor After Timing Belt Change - Searched
Old May 1, 2007 | 08:48 AM
nexgen91's Avatar
Default Solid CEL and ECU Code 9 CPY Sensor After Timing Belt Change - Searched
My timing belt on my 1.6i-16 (ZC) snaped and I had to replace it. After replacing it I turned the motor over by hand and everything seamed to be ok. It starts up fine, but I get a solid CEL and the ECU flashes a code 9 constantly (I know its a cylinder position sensor error or something like that). Its plugged in though. If I let the car idel for to long it cuts off. The vavles sound like they need to be adjusted. And Im note sure if the timing is off or not, but the performance is not degraded. I did a compression test and got these results: (Dizzy) 185 175 165 180 (Timing Belt) What could be the problem here? Thanks
Old May 1, 2007 | 10:20 AM
nexgen91's Avatar
Default Re: Solid CEL and ECU Code 9 CPY Sensor After Timing Belt Change - Searched (nexgen91)
TTT
Old May 1, 2007 | 12:24 PM
nexgen91's Avatar
come on, someone help me out
trav_89_crx_b7
Sep 26, 2011 02:54 PM
SPORT INJECTION
22
May 30, 2006 04:15 PM
civic_dork
Jul 3, 2005 07:40 AM
padraf
Jul 14, 2004 02:49 PM
red civic standard
Jul 14, 2002 07:25 PM
