p28 or p30 whats better
to me....honestly everyone seems to do the obd0 to obd1 swap...so i would say OBD1.
thats what im doing also, OBD1 conversion, then hondata s300...
if you do it, tell me how it go's. good luck
If you talk to a competent chipper, they'll tell you that it doesn't really matter what you use, P06, PR4, P08, P28, P30, and if you're using crome, even for a base map, you can disable whatever sensors you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PleaseKeepOffDunes »</TD></TR><TR><TD CLASS="quote">to me....honestly everyone seems to do the obd0 to obd1 swap...so i would say OBD1.
p28 and p30 are both OBD1 computers.. p28 are usually a little cheaper than the p30 but not as cheap as the p06, pr4, and p08 mentioned above. Stock b16 I would run a stock p30, otherwise buy another computer and tune it.
I just bought a s300 / p28 setup to run with
</TD></TR></TABLE>p28 and p30 are both OBD1 computers.. p28 are usually a little cheaper than the p30 but not as cheap as the p06, pr4, and p08 mentioned above. Stock b16 I would run a stock p30, otherwise buy another computer and tune it.
p28 is great, but I dont think it matters which ecu of the two, since your using a standalone system anyway, and you'll be able to do custom tuning with hondata, correct me if im wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY »</TD></TR><TR><TD CLASS="quote">
o ok, didnt realize that, thx for the info on the different computer being OBD1..thx alot, my bad for the bad info
then p28 then hondata
</TD></TR></TABLE>o ok, didnt realize that, thx for the info on the different computer being OBD1..thx alot, my bad for the bad info
itrdelsol
Northern California (Sales)
Aug 16, 2006 06:10 AM
