in process of building POORMANS TYPE R....have sum questions
Old May 1, 2007 | 03:38 AM
poormans_typer69's Avatar
Default in process of building POORMANS TYPE R....have sum questions
im building my a poormans type r right this moment at the machine shop the bottom is getting finished right now but i want to know what i can use for the top end...
1. should i use the expensive valve and valve springs skunk 2 has or should i use some otha aftermarket...
2.im gonna be doing high compression so i want to know how big my injectors can be...
if any1 has done this setup of b16 head and gsr block with high com. pistons, stage to camshafts, fully rebuilt let me kno..
Old May 1, 2007 | 04:31 AM
Jay_Sensing's Avatar
Probably get a lot more help if you took the time to actually spell your words, you know, make an effort to make it easy for us to read, people would probably make more of an effort to help you out.
That being said, it's been done about 20 times with great success. Don't bother with valves because the stock ones will be perfectly fine. If you have a bad day and have piston to valve contact, you will just bend an OEM valve vice shattering an aftermarket valve.
Skunk2 springs and retainers are perfectly fine. I use them in my PR3 head and turn my car to 9400 at the track with no issues and Skunk2 Stg2 cams.
What compression are you going to end up with and what cams. Header, intake mani, exhaust, and so on? Most likely you will be fine with a set of 310's and a walbro pump.
Old May 1, 2007 | 06:36 PM
Default Re: (Jay_Sensing)
sorry about the spelling i just write like that when im in a hurry...thanks for the info on the valves and retainers...i guess im going to go with skunk 2 spring and retainers...
the camshafts that im using are skunk2 stg 2... i want to use itr or ctr headers...aem cams....and apexi n1 catback exhaust...skunk2 intake magni....i think ill follow what you said about the fuel pump...
also what do you think about a bigger throttle body maybe a type r one ????
DerekHollister
Engine Machining & Assembly
Sep 23, 2015 02:36 AM
PROJECT_HATCH59
Oct 1, 2010 01:32 AM
killerpenguin21
Nov 21, 2006 09:26 AM
JFG Kevin
Sep 21, 2004 01:18 PM
