96 ek dx climate problem......
Old May 1, 2007 | 01:25 AM
rickeg6's Avatar
Default 96 ek dx climate problem......
I search here and cant seen to find what i'm looking for so i need help. My 96 ek climate control is acting crazy on me. It started fine for the first week when i bought it, everything work, the blower blow air and ac blow cold air. THen all of a sudden when i turn on the blower nothing happen. the blower stop blowing when i turn the switch to 1,2,3,4. The ac light up and the ac fan spin when i press the ac button. SO i thought the blower went out. I took the blower out and tested it and it sppin like normal. I then thought the switch on the climate control went bad. So i bought a used climate control unit and it still doesnt turn on the blower. I check the wiring under the dash and there is no burn or loose wire from the blower to the climate control.
any other suggestion would be appreciated.
Old May 1, 2007 | 01:35 AM
Eran's Avatar
HT White Ops
It sounds like the fan speed switch (1-2-3-4) is fried. Just buy a used climate control from someone on the forum.
Old May 1, 2007 | 03:03 AM
rickeg6's Avatar
Default Re: (Eran)
i bought the whole climate control piece and it doesnt work. is that what you are talking about?
Old May 1, 2007 | 05:14 AM
MugenManR's Avatar
Default Re: (rickeg6)
i got the same problem, absoltely nothing is workin not even the little lights on it. so if anyones got a solution(s) that would be cool.
Old May 1, 2007 | 12:16 PM
JDM-EKcivic's Avatar
Default Re: 96 ek dx climate problem...... (rickeg6)
i had the same problem i tried to fix it made it worst so i brang it to a garage n they told me that i had to take my whole center peice off and check this wire check that wire i gave up n letted them do it, it only costed me about $45 better then making things worst
Old May 1, 2007 | 02:53 PM
rickeg6's Avatar
i guess this is common for 96 up civic then
damn i really need **** fix before the summer comes. The shop would be my last option. PLease i need help.........
Old May 1, 2007 | 08:11 PM
MugenManR's Avatar
prob is i cant get my car to a shop.. interiors not quite together for that andd, a it dont roll. wondering can i just bring it to a garage with the interior in peices so they wont have as much labor?
Old May 1, 2007 | 08:25 PM
dtapia's Avatar
Default Re: (MugenManR)
you can check the blower motor resister is a pretty normal thing to go out.i have trouble shooting info but you have to e mail me since it in pdf form and i cant post it here.
dinotapia@sbcglobal.net
bjgill333
May 27, 2013 07:57 AM
tylergwesterhold
Jun 5, 2008 04:29 PM
Hehehe I just
May 3, 2004 02:31 PM
