88 crx zc dohc wont start HELP !!!
Old Apr 30, 2007 | 09:54 PM
Phils's Avatar
Default 88 crx zc dohc wont start HELP !!!
i was driving my crx and i was coming into my driveway and my car made light ticking noises and the car shut off and died. Starter works, battery is strong, timing belt is good, but car will not start, battery light indicator is on when i start it i dunno what it is. if anyone has any suggestions it would really help me out. thanks
Old Apr 30, 2007 | 10:10 PM
Deetz's Avatar
Crazy Honda Guy
1st thing to do is check for spark. Also, pull of the distributor cap and see that the inside of your dizzy isn't eaten up, thats happened to me 3 time with different ef's now.
Old May 1, 2007 | 08:00 AM
driftdas2000's Avatar
Default Re: 88 crx zc dohc wont start HELP !!! (Phils)
check the main relay first you shoul here 2 clicks and the check engine light should come on for a few sec. and go off. the main relay is a two part relay powering the fuel pump and the other part powers the ecu
Old May 1, 2007 | 08:16 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 88 crx zc dohc wont start HELP !!! (driftdas2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftdas2000 &raquo;</TD></TR><TR><TD CLASS="quote">check the main relay first you shoul here 2 clicks and the check engine light should come on for a few sec. and go off. the main relay is a two part relay powering the fuel pump and the other part powers the ecu</TD></TR></TABLE>
Start here first. This is a common weak link for our vehicles.
Old May 1, 2007 | 08:41 PM
Phils's Avatar
Default Re: 88 crx zc dohc wont start HELP !!! (wiZCo)
the starter turns the flywheel, but its jsut not starting and the battery indicator is on on the dash could that be the main relay?
Old May 1, 2007 | 08:46 PM
Deetz's Avatar
Crazy Honda Guy
Main realys don't just go while your driving. An ignitor could, or possably a short in your altenator.
Old May 1, 2007 | 10:07 PM
Phils's Avatar
Default Re: (Deetz)
yeh thats wut i thought, so u think its the alternator... i just put a new dizzy on it like a month ago ....
Old May 2, 2007 | 11:06 AM
Phils's Avatar
Default Re: (Phils)
does anyone have any other suggestions ?
Old May 2, 2007 | 03:53 PM
Phils's Avatar
Default Re: (Phils)
dizzy is good still wont start ...
Old May 7, 2007 | 09:48 PM
Phils's Avatar
Default Re: (Phils)
ok so over the weekend i checked the alternator and my car still doesnt start ...
Old May 7, 2007 | 10:08 PM
xlr8_si's Avatar
I got the same freakinn problem. BUMp
Old May 8, 2007 | 03:34 PM
Deetz's Avatar
Crazy Honda Guy
It's not hard to figure out, all an engine needs to run is:
- fuel
- compression
- spark
Timing plays a role too.
Old May 8, 2007 | 11:18 PM
Phils's Avatar
Default Re: (Deetz)
what can be the cause of loss of compression ?
Old May 8, 2007 | 11:25 PM
Under Con. CrX's Avatar
Default Re: (Phils)
do you know your car has loss of comp. or is that a guess
Old May 8, 2007 | 11:45 PM
is this what it sounds like ???
Old May 9, 2007 | 10:50 PM
Phils's Avatar
Default Re: 88 crx zc dohc wont start HELP !!! (Under Con. CrX)
yes it does sound like that but i dunno if it is fuel pump
Old May 9, 2007 | 10:59 PM
downest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con.CrX &raquo;</TD></TR><TR><TD CLASS="quote">
is this what it sounds like ???</TD></TR></TABLE>
What was wrong with that one? That sounded like my friend's DA when her dizzy seized.
Old May 10, 2007 | 01:33 PM
the reson my sounded like that its cus i had no compression but fills if yours ran before this there is no reason why you should have no compresion and if you said that there whas a slight ticking than you might have had the same problem i did
the valves where to tight and it hit my pistons i hope this did happen to yours cus you going to need a new motor
PS hey phils its PeDrO
Old May 10, 2007 | 08:40 PM
Phils's Avatar
naw it still puts out the exhaust when i crank it like i can hear it putting from the exhaust ..... it was running before i dunno why all of a sudden it would just stop like that ???
Old May 10, 2007 | 08:42 PM
Phils's Avatar
and im sure i would have heard the valves hit the pistons right ?
Old May 10, 2007 | 11:34 PM
well you said it was tiking before it died
and yeah its still going to put out unless all your pistons are
fuked
Old May 11, 2007 | 05:36 AM
s0001656's Avatar
check distributor rotor/timing/axel bearing - if the distributor
axel bearing is not ok, the rotor might have taken heavy contact
against disrtibutor cap terminals, and the rotor position and
timing migth be wrong (happened to my d16, timing was about
180 degrees off)
Old May 11, 2007 | 03:00 PM
Phils's Avatar
Default Re: 88 crx zc dohc wont start HELP !!! (s0001656)
yeh it was light ticking not my pistons killing valves so the same thing happened tp yer d16 did it make light ticking noises ???? before it shut off
Old May 12, 2007 | 12:12 AM
phils i had a d15 in my civic come on dude and no it didnt shut off it just ran and sounded like super crap but listen to the other guy on top of your last post thats what i would do or if you have any spare cash i can give you the number to a mobile mechanic that wont charge you an arm and a leg
Old May 12, 2007 | 03:48 AM
Sikocivic's Avatar
Check your Cam timing. It sounds like the timing belt slipped and jumped a few teeth. Thats why it cranks like it has no compression. It may be firing the spark plugs when the valves are open. I have seen this happen before.
