Cleaning EGR port
Old Apr 30, 2007 | 09:41 PM
mnorrell's Avatar
Default Cleaning EGR port
ok guys, i have a question...I have no clue about working on cars, but im a very quick learner and can follow directions or pictures. i just bought a 2002 v-tec honda accord and the check engine light was on so i did a diag. test. It said the EGR port needed to be cleaned. I was looking around to see if i would be able to do it myself. one, can u just take off the plate covering the ports and clean them? If so, what do you recommend me cleaning them with? Second, does anyone have a detailed explanation on how to do it with pics? Its my fiance's car and i really dont want to spead a whole lot of money. please help!!!!
Old Apr 30, 2007 | 09:47 PM
lowered94accord's Avatar
Default Re: Cleaning EGR port (mnorrell)
http://members.troublecodes.ne...R.htm
thats for a 5th gen accord but it should be about the same for your model accord and yes you just take the plate off..clean it with carb cleaner and alittle metal brush of somesort..thats what i did anyways worked awesome
Old Apr 30, 2007 | 09:51 PM
mnorrell's Avatar
Default Re: Cleaning EGR port (lowered94accord)
ok, when i hand drill out the port do i have to worry about any of the carbon buildup falling into the holes?
Old May 1, 2007 | 03:17 AM
TouringAccord's Avatar
H-T Order of Merit
Do you have a V6 or a I4?
Old May 1, 2007 | 04:28 AM
mnorrell's Avatar
Default Re: Cleaning EGR port (TouringAccord)
I have a V-6. Also, besides the 4 holes are there any tubes i need to clean out? how long does this take...From the pics it doesn't seem like it takes long.
Old May 1, 2007 | 06:04 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Cleaning the 2002 Accord EGR port is somewhat different than the 5th gen Accord. You may want to first check with Honda if this is covered under their extended emissions warranty.
Here is a Technical Service Bulletin (TSB):
http://www.tegger.com/hondafaq...5.pdf
H-T Order of Merit
ok, well, since you have a V6 that link above isn't going to be much help since thats for the 94-97 4cyl engines and the V6 egr cleaning is different.
After some searching, which the egr is a common question and there is a lot of topic returns when you search the archives of just Accord forum just search for EGR and you'll see what I mean, I found this...
http://members.troublecodes.ne...5.gif
Now that is instructions on a warranty extension but it does show you how to clean the egr ports of the V6 engine.
EDIT:
Damn... tech8 and I posted at the same time, he beat to it though
Old May 1, 2007 | 07:50 AM
mnorrell's Avatar
Ok, thank you very much...I think im goign to try and follow the directions and do it. But if im only cleaning the ports and not replacing the valve do i still have to Remove the throttle body cover, intake manifold
covers, ignition wire holder, and ignition wire cover? Can i leave this stuff on or does it have to come off? Im a real newbie, so i need all the help i can get!!!!
I REALLY appreciate all the help yall are giving me!!!
Old May 1, 2007 | 09:37 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Try contacting American Honda or the dealer first. You have nothing to lose, since they may cover the EGR port cleaning.
Old May 1, 2007 | 03:15 PM
Twistedframe's Avatar
Default Re: Cleaning EGR port (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnorrell &raquo;</TD></TR><TR><TD CLASS="quote">ok, when i hand drill out the port do i have to worry about any of the carbon buildup falling into the holes? </TD></TR></TABLE>
X2... Is that a bad thing to have that carbon gunk fall into the manifold runners?
I assume the small amount that does fall into it would just be incinerated in the combustion chambers. It's probably nothing more than a light snack for the engine to munch on. Perhaps I'll just put the vacuum cleaner nozzle right there next to the spot that I'm drilling to suck up the crap that gets knocked off.
Old May 1, 2007 | 07:52 PM
Default Re: Cleaning EGR port (Twistedframe)
well think of it this way..the carbon build up that is in those holes came from down in there so how would it hurt it?..that where it came from so its not going to hurt anything
Old May 2, 2007 | 05:35 AM
mnorrell's Avatar
Man, yall are a TON of help.... OK, i checked out the car yesterday and i see the four covers im supposed to take off that are on top of the manifold. I'm only worried that once i get the intake manifold off and i clean out the port on the bottom that i wont be able to get it back in the car. Once its out is it hard to get back in?
Old May 2, 2007 | 05:38 AM
H-T Order of Merit
I've never taken the intake manifold off on a V6 Accord but I can't imagine it's going to be any harder than removing it, probably easier to install than it is to remove because you already know how it all came apart and that. Make sure you use new gaskets when re-installing everything.
Old May 2, 2007 | 05:55 AM
mnorrell's Avatar
Ok, ill get new gaskets to put on. Should i use some carberator cleaner when the port and should i clean the runners?
Old May 2, 2007 | 06:05 AM
H-T Order of Merit
carb cleaner is fine to use.
might as well clean the runners as well while you have it off the engine.
Old May 2, 2007 | 10:08 AM
mnorrell's Avatar
ok, so heres the deal. my fiance took the car to the dealership to get a alignment and tire pluged and they were like you need to replace the egr plugs. Where are the plugs? are they hard to fix? What would happen if i just cleaned out the port and kept the plugs? HELP!!!!!
Old May 3, 2007 | 05:09 PM
accordv6kikaz's Avatar
Check this thread link below. Accord99v6 did a good tutorial with pictures on solving the egr problem with minimal dismantling. Also has TSB link with info on torque spec of bolts etc.
http://www.honda-acura.net/for...02092
YUNGSTER323
Classic Hondas
40
Feb 7, 2013 08:27 PM
nhldogg
Apr 17, 2010 11:32 AM
myjunkaccord
Classic Hondas
Oct 30, 2008 09:50 PM
accord-euro
Mar 12, 2006 10:35 AM
Swerve
Nov 28, 2001 08:52 AM
