Build Question
Well I just pieced together a b16a swap well I got the car started but it was only running on two cylinders I had spark and fuel in all cylinders. Me and my friends thought it would be the valves got bent because the timing belt jumped a little. So having the valves replaced any other ideas it could of been. thanks for help
Before you replace valves...
It could also be bad rings, or a headgasket not sealing right. How do you know you're getting fuel and spark? What is your compression and which cylinders are "bad?"
bnuk013
Jul 19, 2006 08:36 AM
FOC-US2K
Aug 12, 2005 05:28 AM
