!!!!!!!! please help =[ !!!!!!!
Old Apr 30, 2007 | 06:15 PM
Lamafia ck's Avatar
Default !!!!!!!! please help =[ !!!!!!!
i have a 96 hatchback with a b18b swap,i changed the engine harness to an automatic 97 civic coupe harness because i had to many cut wires from the ecu plug on my old harness . the car cranks and everything but the motor is not receiving fuel. the fuel gauge does not go up it stays at 0 psi.its making a ticking noise from the main relay the one that is inside the glove compartment and the speedometer needle goes up and down by itself . i changed the fuel pump and the relay ,and it still didnt work. i tried my ecu on my friends car and it works fine. i need to know if i can actually use the automatic harness . i really need help i lost my job over it! !!!!!!
i'm using a chipped p75
mudandrox
Jun 3, 2016 10:10 AM
Civic98KH
Nov 20, 2015 04:19 PM
dc2_build
Jan 16, 2010 09:35 PM
Lamafia ck
May 1, 2007 09:27 AM
Lamafia ck
Apr 30, 2007 07:56 PM
