got a question
Old Apr 30, 2007 | 06:09 PM
19992civichatch's Avatar
Default got a question
whats the c clip the holds the retainer down on the vlave called, and second i got new valves, valve springs, and retainer do i need new "c-clips"
Old Apr 30, 2007 | 06:11 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: got a question (19992civichatch)
for the second question, as far as your old c-clips look okay it should be fine, if they look worn/corroded at all I'd replace them.
I'm sure honda carries them.
EDIT: C-clips = keepers
Old Apr 30, 2007 | 06:14 PM
Luserkid's Avatar
Default Re: got a question (ek forever guy)
"c-clips" as you call them are called Keepers.
I have yet to see a set of keepers go bad (usually they get lost). Retainers are known to give out before the keepers.
Old Apr 30, 2007 | 06:26 PM
alright thanks guys
Old Apr 30, 2007 | 06:53 PM
1d10t's Avatar
Default Re: (19992civichatch)
you need to look at the edges of the keepers ( the edge that fits into the valley of the valve). if they show a worn flat edge, replace. You should replace anyways. Those keepers were worn on a certain seat pressure and max pressure. Now youre increasing all of the above. They do go bad btw. I used to work for DPR, and we always replaced the keepers.
Old Apr 30, 2007 | 07:08 PM
my head is a gsr can i use b16 keepers?
Old May 1, 2007 | 10:53 AM
1d10t's Avatar
yes
jkn1515
Aug 14, 2006 03:16 PM
4DRmafia
Dec 29, 2005 08:58 PM
GReddyTurboCoupe
Jul 17, 2005 03:15 PM
ludesleep
May 27, 2003 10:48 AM
