accelerating surge problem
Old Apr 30, 2007 | 06:02 PM
b16bej1's Avatar
Default accelerating surge problem
need help, i replaced my t-stat, fuel filter and pump. i have no engine lights. holding a rev higher than 2000 rpm it drops roughly around 1000 rpm. any help appreciated.
Old Apr 30, 2007 | 06:05 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: accelerating surge problem (b16bej1)
I'm not really following what you're asking, could you re-phrase that?
Old Apr 30, 2007 | 06:09 PM
b16bej1's Avatar
holding a rev at a stand still, the rpms go up and down almost like a vacuum leak, but my idle is fine. i have a 94 ej1 with a 97 b16b swap
Old Apr 30, 2007 | 06:13 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16bej1 &raquo;</TD></TR><TR><TD CLASS="quote">holding a rev at a stand still, the rpms go up and down almost like a vacuum leak, but my idle is fine. i have a 94 ej1 with a 97 b16b swap</TD></TR></TABLE>
Um, So i take it you checked for vacuum leaks?
Did you try the regulars? Fast Idle thermo valve, Throttle body, and Ide air control valve?
Old Apr 30, 2007 | 06:17 PM
b16bej1's Avatar
Default Re: accelerating surge problem (ek forever guy)
i cleaned my fitv and my iac, but i didn't swap throttle bodies yet. i'll try that tomorrow. i'll let you know how it goes. thanks for the help.
Ek Forever y0!
I wouldn't necessarily swap them, but I'd make sure to clean it out with carb cleaner.
Old Apr 30, 2007 | 06:21 PM
b16bej1's Avatar
oh, yeah i did that, i don't know what else to do
Old Apr 30, 2007 | 06:32 PM
97Ej6mike's Avatar
Are you sure you have the correct ECU?
Old Apr 30, 2007 | 06:38 PM
b16bej1's Avatar
Default Re: (97Ej6mike)
before i had a jdm b16a swap and used the jdm ecu that came with the swap, unless the b16b parameters are different. but i sold my original d16z6 ecu and my ctr ecu (figured i didn't need a obd2 ecu).
Old Apr 30, 2007 | 06:42 PM
1d10t's Avatar
Default Re: (b16bej1)
could be MAP.
Old May 1, 2007 | 08:05 AM
97Ej6mike's Avatar
Default Re: (1d10t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1d10t &raquo;</TD></TR><TR><TD CLASS="quote">could be MAP. </TD></TR></TABLE>
Possibly, ive had problems with the map before, related to the idle as well. So you are sure you arent getting any Check engine lights?
Old May 1, 2007 | 08:45 AM
Ek Forever y0!
yes, if you're running a K&N filter it's probable that the oiled filter may have clogged up the sensor. Might want to check that out as well.
ilovemyh22
May 6, 2009 12:54 PM
Nachos
Jul 28, 2008 09:38 AM
sikwitit
Nov 8, 2005 02:50 PM
civic ex-r
Sep 27, 2005 10:19 PM
wolf3007
Mar 26, 2004 05:06 AM
