accelerating surge problem
need help, i replaced my t-stat, fuel filter and pump. i have no engine lights. holding a rev higher than 2000 rpm it drops roughly around 1000 rpm. any help appreciated.
Re: accelerating surge problem (b16bej1)
holding a rev at a stand still, the rpms go up and down almost like a vacuum leak, but my idle is fine. i have a 94 ej1 with a 97 b16b swap
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16bej1 »</TD></TR><TR><TD CLASS="quote">holding a rev at a stand still, the rpms go up and down almost like a vacuum leak, but my idle is fine. i have a 94 ej1 with a 97 b16b swap</TD></TR></TABLE>
Um, So i take it you checked for vacuum leaks?
Did you try the regulars? Fast Idle thermo valve, Throttle body, and Ide air control valve?
Re: accelerating surge problem (ek forever guy)
i cleaned my fitv and my iac, but i didn't swap throttle bodies yet. i'll try that tomorrow. i'll let you know how it goes. thanks for the help.
Re: (97Ej6mike)
before i had a jdm b16a swap and used the jdm ecu that came with the swap, unless the b16b parameters are different. but i sold my original d16z6 ecu and my ctr ecu (figured i didn't need a obd2 ecu).
Re: (1d10t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1d10t »</TD></TR><TR><TD CLASS="quote">could be MAP. </TD></TR></TABLE>
Possibly, ive had problems with the map before, related to the idle as well. So you are sure you arent getting any Check engine lights?
