Aftermarket 2" tach - works etc.. but lighting wire? Help.
Old Apr 30, 2007 | 04:56 PM
allsho's Avatar
Default Aftermarket 2" tach - works etc.. but lighting wire? Help.
okay... simply put
installed tach
- power wire to radio fuse
- grounded on bolt
- wired to dizzy
but there is one more wire
a white "lighting" wire..
it's day light out right now and i cant tell if it is lighting up, but i dont think it is.
Does anyone know the easiest place i can wire this lighting wire... ?
88 civic dx thanks.
Old Apr 30, 2007 | 04:57 PM
allsho's Avatar
ttt, quick help needed! lol this should be a simply answered question
Old Apr 30, 2007 | 05:19 PM
90crxdriver's Avatar
Default Re: (allsho)
When I had one in my car I just put the light wire to the same place I pulled power from for the tach.
When the tach came on, the light came on. simple
Old Apr 30, 2007 | 05:56 PM
slaminsam's Avatar
i wired mine in to the head light circuit you can get one of them connecters that just peirces the wire and the other wire clips into it
Old Apr 30, 2007 | 06:01 PM
91ed9's Avatar
Default Re: (90crxdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdriver &raquo;</TD></TR><TR><TD CLASS="quote">When I had one in my car I just put the light wire to the same place I pulled power from for the tach.
When the tach came on, the light came on. simple</TD></TR></TABLE>
yup just wire the light and power together and then ground it and then the Tach lead wire
done simple no headaches
Old Apr 30, 2007 | 09:17 PM
allsho's Avatar
figured it out!
I put the red wire (power) into the radio fuse.. (wrapped it around)
Then for the light on the tach (white wire) I put it into the instrument light fuse...
And it worked!
By the way, if any of you find this thread in a search (never know)...
Just a heads up..
When you wire up with the fuses, some times only 1 prong on the fuse will work just dont worry and just test it!
pair8hd
Dec 1, 2007 03:44 PM
nitroaccord105
May 16, 2007 05:09 PM
variable
Jan 28, 2004 12:49 PM
cpizzy
Dec 31, 2003 08:39 PM
crx_ef8
Mar 10, 2003 10:47 PM
