need help, ls wont start
Old Apr 30, 2007 | 02:18 PM
iheartteal's Avatar
Default need help, ls wont start
first off id like to tell every1 i did search and found alot of stuff on this but it didnt help.
this is a 91 civic hatch si w/ ls swap and converted to obd1
I have no sprak and my fuel pump is not kicking on, i have checked all the fuses, i have swapped out the main relay,tried my buddies ecu and have checked most of the grounds i could find. i also had an extra ignition switch and tried swapping those out and still get nothing. My check engine light is on and stays on but i cant get it to flash a code. the car will crank all day long.
can some1 please point me in the right direction
thank you
Old Apr 30, 2007 | 03:00 PM
Janos Lin's Avatar
Default Re: need help, ls wont start (RideroftheHonda)
Did u jumper it so it will flash the code?
Check your conversion harness as well, and make sure the big fuses in the underhood fuse box isn't blown.
Janos
Old Apr 30, 2007 | 03:09 PM
jedb18's Avatar
Default Re: need help, ls wont start (Janos Lin)
I had the same problem when I converted my hatch to obd-1 with my ls, I had to cut the connector that went to the old resistor box and twisted the wires together and it started right up
Old Apr 30, 2007 | 06:40 PM
iheartteal's Avatar
yea i jumped it so it would flash.
bump need this thing goin, the truck is killing me in gas
Old May 1, 2007 | 01:08 PM
iheartteal's Avatar
up
Old May 1, 2007 | 03:59 PM
tougetuned_ef's Avatar
Default Re: (RideroftheHonda)
by jumping did you use a jumper harness. it a little plug on the driver side with a rubber cap on it and i always use a saftey pin with the head cut off to jump it together. pm me and i can text a pic to you tomarrow. it will make the cel light blink your code.
Old May 1, 2007 | 06:42 PM
vtecspeed1320's Avatar
Shooting Star
did the car run before and all of the sudden shut off?
Old May 3, 2007 | 01:29 PM
iheartteal's Avatar
Default Re: (vtecspeed1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">did the car run before and all of the sudden shut off? </TD></TR></TABLE>
yea the car was running for like 2 months and then it just shut off, i thought it was just the coil in the distributer, but then i noticed the fuel pump was kickin on, im thinkin that maybe there is a bad ground somewhere but i checked all the under hood ones and they seem to be ok, is there any grounds in the interior that may cause my problem
Old May 3, 2007 | 01:50 PM
Janos Lin's Avatar
Check out the electrical service manual, has the wiring diagram and pics of where all the grounds are.
Janos
Old May 3, 2007 | 01:54 PM
burnt_rice's Avatar
probably not cause majority of the problem when doing a conversion are within the converted wires or related areas which do not include (with the exception of the ecu) the interior wires my guess is there is a loose wire somewhere which grounded incorrectly and it's causing a short. Did you convert your car to Obd1 yourself if so check the continuity of the wires for ignition..good luck i'll keep an eye on this to see if i can help you out a bit
Old May 3, 2007 | 02:02 PM
Shooting Star
who did the swap? did anyone splice any wires etc etc.
Old May 4, 2007 | 01:23 PM
iheartteal's Avatar
i did the swap my self, but when i baught the car there were some spliced wires near where the ecu plug in is but from what i can tell theyve all been soldered together, i think ima go to the junkyard this weekend and get a different harness, thanx for the help so far, let me know if you can think of anything else
Old May 6, 2007 | 01:26 PM
burnt_rice's Avatar
looking for an update
Old May 8, 2007 | 02:35 PM
iheartteal's Avatar
didnt have time to work on it this weekend but will definatly try and get it done this week thx for the help so far
Old May 11, 2007 | 01:17 PM
iheartteal's Avatar
update.
i tried a known good main relay out off my buddies crx with an ls, and i had no luck. so i checked the voltage at the plug on his crx and he has 12 volts on 3 of the wires, and i have 12 volts on only one of my wires, does anyone know where i can get a good wiring diagram off the internet, i have a haynes manual but the wiring diagrams in there arnt very good.
still cant get a code to flash, i just tried touching the wires on the rywire harness thats used to flash the code and it doesnt do anything, is there another way?
Modified by RideroftheHonda at 4:47 PM 5/11/2007
Old May 15, 2007 | 03:14 PM
iheartteal's Avatar
alright guys i got some progress now. i got a better wiring diagram than wut i had and it led me to a fuse that was the only one i didnt check because i figured it had nothing to do with my problem. it was the alternator solenoid valve fuse. i replaced it and now i have spark but no fuel. i checked the voltage to the wire going to the fuel pump from the main relay and i have none, any ideas
Old May 15, 2007 | 07:11 PM
iheartteal's Avatar
up
Old May 15, 2007 | 07:44 PM
Janos Lin's Avatar
U gotta listen for it because it's only on for 2 seconds to prime the fuel lines then it shuts off until the engine starts running. Cycle the key to make it come on.
Janos
Old May 16, 2007 | 01:38 PM
iheartteal's Avatar
i have a walbro pump and that thing is loud, and i also have a fuel pressure guage that isnt reading any pressure, so i kno its not kickin on
Old May 16, 2007 | 03:41 PM
Janos Lin's Avatar
Ok what color was the wire u were getting 12V from? Did u check fuses 2 and 14 for the dash fusebox and fuse 37 under the hood? Might want to check all of the fuses though.
Janos
Old May 16, 2007 | 07:05 PM
iheartteal's Avatar
im getting power to the yel/wht, blk/yel with the key in the on pos and the main relay unplugged, and im getting power to the blu/wht while cranking, and power to all the wires except the black (ground) and yel/blk wire going to the fuel pump, i will double check the fuses tomorrow
Modified by RideroftheHonda at 10:16 PM 5/16/2007
Old May 16, 2007 | 08:41 PM
Janos Lin's Avatar
Sounds like you have an open circuit somewhere between the main relay and the fuel pump. Where were you checking for voltage on the yel/blk wire to the fuel pump?
Janos
Old May 17, 2007 | 01:28 PM
iheartteal's Avatar
i was thinking that same thing, but i checked for continuity (ohms) starting where the wire comes out of the main relay going to the ground side and i had like .4 or sumthin, but i think i figured it out, i tried hooking 12v straight to the pump and it didnt click on so ima end up gettin a new pump now. thx for the help so far.
98boostedy8
Apr 14, 2009 08:34 PM
yellowjdmcrx
Feb 15, 2008 01:00 PM
vroompsshht
Sep 14, 2006 05:07 PM
psycho.chicken
Jul 16, 2006 08:39 AM
R_type
May 31, 2005 11:24 AM
