i got 06 tranny in my 03 is there a conversion kit for the speed sensor
Old Apr 30, 2007 | 12:48 PM
rsx169's Avatar
Default i got 06 tranny in my 03 is there a conversion kit for the speed sensor
ok i got a 03 rsx and i just put in a 06 tranny but the problem is that the speed sensor are not same is there a conversion kit or want should i do ???
Old May 1, 2007 | 03:37 PM
AcuraTech23's Avatar
Default Re: i got 06 tranny in my 03 is there a conversion kit for the speed sensor (rsx169)
YOU ARE OUT OF LUCK IF YOU HAVE ALREADY BOUGHT IT BECAUSE BOTH TRANS HAVE MINOR DIFFERENCE BUT ARE NOT INTERCHANGABLE UNLESS MAJOR WORK IS DONE TO IT. IF YOU WANT TO SWAP THE 05-06 TRANS INTO THE 02-04 RSX YOU WILL NEED TO TAKE THE TRANSMISSION APART, INSTALL A SPEEDO GEAR ONTO THE DIFFERENTIAL AND THEN DRILL AND TAP THE HOLE FOR THE GEAR TYPE SPEED SENSOR USE IN THE 02-04 RSX. THE 05-06 RSX USED A MAGNETIC PULSE TYPE SPEED SENSOR WHICH READ MORE ACCURATE AND IS LESS LIKELY TO GIVE IMPROPER SIGNAL TO THE PCM. THAT IS ONLY MINOR, HERE IS WHERE IT GET HARD AND EXPENSIVE, THE WIRING IS ALSO DIFFERENT FROM THE ENGINE WIRING HARNESS TO THE COMPLETE UNDERDASH WIRING HARNESS. THE REASON FOR THIS IS ALSO BECAUSE OF THE NEW PULSE TYPE SPEED SENSOR, HONDA'S ENGINEER MUST USE DIFFERENT WIRING TO USE THIS TYPE OF SENSOR. I BELIEVE IT WILL BE A MUCH BETTER IDEA TO SELL THE 06 TRANSMISSION AND REBUILD THE 03 TRANSMISSION OR JUST BUY AN 02-04 TRANSMISSION.
Old May 1, 2007 | 03:49 PM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: i got 06 tranny in my 03 is there a conversion kit for the speed sensor (AcuraTech23)
people are running it in k-swaps with k20a2's on k20a.org. i didnt fully read this but he might be able to help you
http://www.k20a.org/forum/showthread.php?t=24320
Old May 1, 2007 | 07:27 PM
aznvietboi87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraTech23 &raquo;</TD></TR><TR><TD CLASS="quote">YOU ARE OUT OF LUCK IF YOU HAVE ALREADY BOUGHT IT BECAUSE BOTH TRANS HAVE MINOR DIFFERENCE BUT ARE NOT INTERCHANGABLE UNLESS MAJOR WORK IS DONE TO IT. IF YOU WANT TO SWAP THE 05-06 TRANS INTO THE 02-04 RSX YOU WILL NEED TO TAKE THE TRANSMISSION APART, INSTALL A SPEEDO GEAR ONTO THE DIFFERENTIAL AND THEN DRILL AND TAP THE HOLE FOR THE GEAR TYPE SPEED SENSOR USE IN THE 02-04 RSX. THE 05-06 RSX USED A MAGNETIC PULSE TYPE SPEED SENSOR WHICH READ MORE ACCURATE AND IS LESS LIKELY TO GIVE IMPROPER SIGNAL TO THE PCM. THAT IS ONLY MINOR, HERE IS WHERE IT GET HARD AND EXPENSIVE, THE WIRING IS ALSO DIFFERENT FROM THE ENGINE WIRING HARNESS TO THE COMPLETE UNDERDASH WIRING HARNESS. THE REASON FOR THIS IS ALSO BECAUSE OF THE NEW PULSE TYPE SPEED SENSOR, HONDA'S ENGINEER MUST USE DIFFERENT WIRING TO USE THIS TYPE OF SENSOR. I BELIEVE IT WILL BE A MUCH BETTER IDEA TO SELL THE 06 TRANSMISSION AND REBUILD THE 03 TRANSMISSION OR JUST BUY AN 02-04 TRANSMISSION. </TD></TR></TABLE>
ohh my caps on.
Old May 2, 2007 | 04:42 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraTech23 &raquo;</TD></TR><TR><TD CLASS="quote">YOU ARE OUT OF LUCK IF YOU HAVE ALREADY BOUGHT IT BECAUSE BOTH TRANS HAVE MINOR DIFFERENCE BUT ARE NOT INTERCHANGABLE UNLESS MAJOR WORK IS DONE TO IT. </TD></TR></TABLE>
WRONG - there is a simple solution of using a speed converter.... A TON of people are using this to run s2000 clusters in older cars
see this thread https://honda-tech.com/zerothread?id=762288 (its rather lengthy)
buy here for $170 http://www.dscustoms.com/s2000cluster.htm OR PM bigcalidave
Modified by 6SPD_EK at 3:18 PM 5/7/2007
Old May 5, 2007 | 09:47 PM
Default Re: i got 06 tranny in my 03 is there a conversion kit for the speed sensor (6SPD_EK)
Well if you read that guy discriptions, it said only for s2000 cluster in different car, he did not say universal or anything for the Rsx. And that box is just for the gauge cluster to work for the car that does have the digital magnetic hall effect sensor. Not for using a transmission in a car that has a regular gauge cluster that used a gear driven speed sensor. If you go to Hondata.com under k20 tech then they will give you the exact same thing that I said prior about swapping in the transmission.
This is from Hondata.com Tech Info
With regard to the speed sensor there are two types of transmission sold with the K-Series.
Low frequency type transmission
Found in the 02-04 RSX and 02-05 Civic Si.
Signal from the speed sensor is at a low frequency.
Speed sensor is at the rear of the transmission, run from the final drive at a low frequency.
The signal from the speed sensor goes both to the ECU and to the gauge cluster.
High frequency type transmission
Found in the 05-06 RSX, TSX and 06-07 Civic Si.
Signal from the speed sensor is at a high frequency.
Speed sensor is at the front of the transmission, from the teeth on 3rd gear.
The signal from the speed sensor goes only to the ECU. The ECU sends a low frequency signal to the gauge cluster.
Matching Components
The following components need to be matched in order for the ECU and gauges to work correctly:
The transmission output speed signal frequency (low or high).
The engine and dash wiring (low frequency design splits the speed signal between the dash and ECU, high frequency design goes from the transmission to the ECU and from the ECU to the dash).
The ECU internal conversion of transmission pulses to speed (in KManager the low frequency type is the default, the high frequency type can be used if the 'Countershaft Driven Speed Sensor' option is selected).
The ECU output of speed pulses to the dash (not present with the low frequency type, necessary with the high frequency type).
If all these components are not matched, then either your ECU speed or your dash speedometer will not work (or both will not work). Repeat: all these components need to be either the low frequency design, or the high frequency design.
How does K-Pro work on the 05-06 RSX?
The speed sensor is the high frequency type.
The engine and dash wiring is the high frequency type.
In KPro you set the speed signal conversion to high frequency ('Countershaft Driven Speed Sensor').
Hondata modifies the 02-04 ECU to provide a low frequency speed output to the dash.
From the last point you can see why an ECU prepared for a 05-06 RSX is different from one prepared for a 02-04 RSX.
How can I get an 05-06 transmission to work in an 02-04?
Everything has to be either low frequency or high frequency. You can either make the transmission into a low frequency type, or the vehicle into a high frequency type.
Converting a high frequency transmission to a low frequency transmission:
Either drill and tap the rear speed sensor location to accept the 02-04 speed sensor, or swap transmissions cases.
Add the speed sensor drive ring to the final drive.
Converting a low frequency vehicle to a high frequency vehicle:
Swap to a 05-06 engine harness.
Swap to a 05-06 dash harness.
Get the KPro changed to 05-06 specifications, with the adapter harness and speed sensor output.
Altering the transmission to a low frequency type is by far the easiest option. However, given the choices you will be best off to sell the 05-06 Transmission and get an 02-04 that will work perfectly from the start.
Old May 7, 2007 | 12:06 PM
6SPD_EK's Avatar
sorry if you have hondata k-pro & speed signal converter - thats all you need!!!
if you any questions PM gamebred26 on k20a.org - he has 05+ tranny WORKING (with proper speed signal to tach by using coverter) in his 02-04 RSX
Old May 8, 2007 | 05:29 AM
6SPD_EK's Avatar
here is a link to the thread... BTW he's running a '06+ civic si tranny in 02-04 rsx-s
http://www.k20a.org/forum/showthread.php?t=25351
oh yeah cruise control doesn't work so if you need that I would go by hondata's suggestion
Acuranoob
Feb 10, 2015 03:01 PM
770_dc2
18
Sep 7, 2012 06:15 AM
Wicked Dance
Apr 13, 2006 08:34 PM
