Keyless Entry: Lights dont flash but car unlocks? How do u make the lights flash?
Ok i got my new keyless remote today and programmed it. The door lock and unlock but the horn doesnt sound and the lights dont flash.
I would like to wire it so the lights at least flash [useful for locating car in crowded lots]- how would i wire it to function this way?
What wire gets power when you press lock/unlock from the remote? All I would have to do is run a wire from that and splice it to the headlights/taillights to make them flash right?
I only want the lights to flash when unlocking.locking via remote, i dont want them to flash every time i lock or unlock from inside the car...
Thanks for any help....
You can make the horn honk...but thats about it
I tried a few years ago to make the parking lights flash too. Tried all sorts of different ways, with and without relays - just wouldnt happen.
I was going about it, using the grey "horn" wire at the back of the deck (its a ground btw) and even a signal from the locks themselves - neither would cause the lights to flash. I think the signal time is just too short
yeah the new control i got doesnt have a option button [but my original one did]
the lock/unlock on this control works but panic doesnt... FCC ID: A269ZUA106
any idea why lock and unlock would work but panic wouldnt?
grr
grr
ok my panic button works, just had to hold it for a second or two...
so my control has lock, unlock, and panic.... when i press lock/unlock the dome light comes on and off... but i cant get the goddamn thing to beep...
does anyone know how to toggle beep with this kinda remote??
I have a remote with the option button (FCC ID: A269ZUA101, CANADA: 700101489, REF NO.HFR-610, P/N: 08E61...). My 1997 Civic User manual says to push the lock and option buttons for 2 sec to turn on/off the horn beep. Also the parking lights flash, but I guess this is related to the Honda security system (control by the same remote) on my car.
I called my Honda dealer and they told me the P/N of the remote which is compatible with my Civic. You can also go to http://www.handaaccesories.com and look for the 3 button remotes which are compatible with your car. Cheers
Blaxican707
Nov 23, 2005 07:24 PM
but a honk would be better than nothing
