Brake cables problem, too short??
Old Apr 30, 2007 | 11:03 AM
HATCHingMN's Avatar
Default Brake cables problem, too short??
Ok, so I have these rear GSR brake conversion.
1st of all, I have this the same GSR rear disc brakes on my 97 EK hatch, I sold the 97 EK hatch and removed the GSR disc brakes and put it into my 99 EK hatch..... now the problem was the E-brake cables did not reach to the handle/adjusment in the center consol. It works on my 97EK how come it did not work on my 99 EK??
Modified by HATCHingMN at 4:49 PM 5/1/2007
Old Apr 30, 2007 | 11:19 AM
HATCHingMN's Avatar
Default Re: Brake cables problem, too short?? (HATCHingMN)
anyone??
Old Apr 30, 2007 | 11:39 AM
HATCHingMN's Avatar
need help
Old Apr 30, 2007 | 11:45 AM
JDM_SOHC's Avatar
yo mine did the same exact thing... everyone told me i got a del sol rear disc setup but i took the setup off of the GSR that i bought it from so if u didnt get a del sol conversion than u just need civic ex w/ abs rear brake cables... i got mine at autozone for like 45-50 bucks a peice "one was more then the other although from what i understand the L and R side are both interchangeable"...
Old Apr 30, 2007 | 11:56 AM
93egsir's Avatar
I would guess that the 99-00 si rear brake cable would be the correct ones. But I am not sure. if you search I am sure there is a how to on the 99-00 ek hatches
Old Apr 30, 2007 | 11:57 AM
93egsir's Avatar
Default Re: Brake cables problem, too short?? (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote"> although from what i understand the L and R side are both interchangeable"... </TD></TR></TABLE>
I know on the eg the cables are left and right due to the mounting brackets
Libertariat's Avatar
Ek Forever y0!
Default Re: Brake cables problem, too short?? (93egsir)
You need 99-00 em1 brake cables.
/thread.
Old Apr 30, 2007 | 12:23 PM
JDM_SOHC's Avatar
Default Re: Brake cables problem, too short?? (ek forever guy)
OP, are both ur civic's coupes.&gt;??
Old May 1, 2007 | 02:58 PM
HATCHingMN's Avatar
well, did not help much...but,
I'll explain some more here,....
****you guys need to read the whole thing to understand what I was asking for.
Old May 1, 2007 | 03:59 PM
HATCHingMN's Avatar
up for more tips
Old May 1, 2007 | 04:07 PM
bmoua's Avatar
the ebrake cables should work bro. I've got ej8 and i have the rear discs off of a gsr worked for me...
Old May 1, 2007 | 06:08 PM
HATCHingMN's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">the ebrake cables should work bro. I've got ej8 and i have the rear discs off of a gsr worked for me...</TD></TR></TABLE>
It work perfectly on my 97 EK hatch, then I remove it and put it on my 99 EK hatch and it was too short.
Did I do something wrong to make it too short??
Old May 1, 2007 | 06:12 PM
JDM_SOHC's Avatar
Default Re: (HATCHingMN)
about 2 inches to short right..?? trust me you need civic coupe w/ abs "rear disc" brake cables, do some researching and i bet thats what ur gonna find out... the civic 2 door an 4 door rear disc ebrake cables are all the same... 92-00 anyways..
Old May 1, 2007 | 06:19 PM
HATCHingMN's Avatar
Default Re: (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">about 2 inches to short right..?? trust me you need civic coupe w/ abs "rear disc" brake cables, do some researching and i bet thats what ur gonna find out... the civic 2 door an 4 door rear disc ebrake cables are all the same... 92-00 anyways..</TD></TR></TABLE>
how come it work on my 97 EK?? and not on my 99EK??
I was thinking that I might have to recheck the line underneath the car, I might of have run over or under something and causing it to be a little too short.
It's about .5"-1" short.
Old May 1, 2007 | 08:11 PM
Tatakai's Avatar
did you put the gsr brakes in ur first hatch yourself? i'm guessing not, usually when goin from rear drums to discs they include cables because the drums are different.
as its been said a few times before, 99-00 si disc cable. /thread
Old May 1, 2007 | 08:39 PM
HATCHingMN's Avatar
Default Re: (Tatakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tatakai &raquo;</TD></TR><TR><TD CLASS="quote">did you put the gsr brakes in ur first hatch yourself? i'm guessing not, usually when goin from rear drums to discs they include cables because the drums are different.
as its been said a few times before, 99-00 si disc cable. /thread</TD></TR></TABLE>
Yes, I bought it and put it in my self. Then removed again and put it in my 99EK and now the problem came up....
I know I could just buy 99-00Si cables but I need a quick fix.
It work on my 97EK, why dont it work on my 99EK??
cincyb20ek
Suspension & Brakes
Jun 12, 2011 02:34 PM
paujc
Nov 29, 2010 06:06 AM
PardonmyEK9
Jul 9, 2010 07:48 AM
Cboi
Mar 13, 2007 11:26 AM
K24EK
Suspension & Brakes
Sep 23, 2005 06:14 AM
