Need hel asap
Ok i got a ticket last week because my break lights weren't working. I checked the fuse, replaced both bulbs and still not working, it's not the break switch because my hatch break light works. Any suggestions?
What have you tested? did you check for power at the bulb socket with a DMM? Did you get the right bulbs? Are the contacts in the socket clean? Help us help you
get a new bulb and see if you can make it light up, if not get a tester light....its like what...$3 at radio shack? and tap the + and the - and see if the bulb on the tester lights up. then not then splice the + and - wire and see if you got power there...if not then go to your fuse box.
hondapwred95
Jul 31, 2005 10:48 AM
