Stock b16 going turbo
Old Apr 30, 2007 | 09:28 AM
Red_em1_51O's Avatar
Default Stock b16 going turbo
I have stock b16 with about 125,xxx miles. I recently bought a turbo from my friend. It's t/3 t4oe 50 trim. it has tial wastegate, some kind of bov, all the charge pipes, oil lines, turbo xs intercooler, Blox manifold, and 2.5" downpipe.. it came with an FMU but i am not trying to use that..I also have the walboro 255 fuel pump. I was wondering if i should use some dsm 450 injectors and get it tuned on chrome? or should i go RC injectors and use a different tune? my basic concern is that i am making this car my daily driver and i want to make it reliable.
Old Apr 30, 2007 | 09:40 AM
Rainy City's Avatar
Default Re: Stock b16 going turbo (Red_em1_51O)
If you want it to be reliable, don't boost it too hard on stock internals.
envee's Avatar
get a leak down test and compression test, if they check out it should be fine for your dd. either way you go with injectors get it tuned, crome is definitely work using.
Old Apr 30, 2007 | 02:54 PM
Default Re: (envee)
thanks of the help..i just plan on boosting about 7psi. I still need to get the jumper harness from obd2b to ob1 but i already have the chipped ecu and i'll probaly just let Dave from DNR in hayward tune my car. i already have an extra tapped b16 oil pan
Old Apr 30, 2007 | 02:56 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Red_em1_51O)
Make sure your valve lash is correct and do the comp./leak down tests.
7psi doesn't mean jack with out the turbo trim.
A smaller turbo on 7psi should be fine for your DD.
Kevin Campbell
Oct 5, 2015 12:52 PM
imsebtactular
Apr 18, 2008 09:11 AM
blackcrx16
Jul 23, 2007 04:41 PM
bluesihatch
Aug 14, 2006 11:35 AM
SIMSSEGA
Mar 15, 2006 02:05 PM
