turbo camshafts for b18b
i have a 93 hatch with a ls in it. going turbo route and need help with camshafts. does anyone have a preference or recommendation on a good set of shafts for turbo apps.... thanks guys
go ask the guys in the integra forum since they're b-crazy. I personally would recommend going LS/VTEC for 1, you have a wider selection of cams and 2, you'd be able to tune it for better power throughout the entire band since you have that extra lift when you need it.
http://www.crower.com/cgi-bin/...02T-2 these are some sexy cams my buddy's running them in hes ls-t and damn...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 »</TD></TR><TR><TD CLASS="quote">how reliable are ls/vtec engines tho??? ive heard great things from and also bad things about reliability ??? </TD></TR></TABLE>
Its the same thing as doing a head gasket job. You do it right, it'll last just as long as a stock gsr. You do it wrong, it'll leak etc blah blah. People have heard bad things mainly becaues idiot high school kids heard about LS/VTEC and began trying to do it themselves without following the necesarry steps.
"WOW LS/VTEC how do you do it"
"just swap the head man its hella easy"
Kid swaps head over and does a 1/2 *** job on timing and wires VTEC up without taping or soldering the connectiongs.... engine leaks at head gasket losing compression...kid doesn't know you're only able to use a head gasket once....it leaks after he tightens it again....then we have crappy LS/VTEC stories.
every motor is only as reliable as the builder and tuner.
lsvtecs are very reliable if built right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 »</TD></TR><TR><TD CLASS="quote">what r his hp figures, do you know? so i take it hes happy with his camshafts</TD></TR></TABLE>
last time it was dyno'd last summer, it was a little shy of 280whp with a stock bottom end and just a chipped ecu.
yeah it's possible he could get up to 350 hp if he just went and got a real tune and not just a chipped ecu plus hes only pushing 8psi. and i used to be a d series man until i bought my h22.
thats not to much power at all . i have hondata s300, sitting at my house and its going to be tuned at some awesome tuning shop in alabama but i havent finished the build tho . if you dont mind me asking why go h-series and how much did you spend on that swap and parts???
yeah it is
on a front wheel drive vehicle there is a definite power limit and certainly <350
You would need to stage boost in the early gears to do anything with that, even then you would need some really good tires
but whatever...
but whatever...
hahaha i wanted something unique and always wanted a h22 so i thought why not just buy an h2b kit too. i spent roughly around 4800 and is susposed to hit mid 13's. i havent ran it yet though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannis. »</TD></TR><TR><TD CLASS="quote">hahaha i wanted something unique and always wanted a h22 so i thought why not just buy an h2b kit too. i spent roughly around 4800 and is susposed to hit mid 13's. i havent ran it yet though.</TD></TR></TABLE>
Wow, ended up a lil pricey.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks-eg6 »</TD></TR><TR><TD CLASS="quote">then what is a good range to be at as far as power for street use goes</TD></TR></TABLE>
If you have a civic with 200-250 whp you'll be fast enough to kill yourself.
sounds far enough. im in the same boat, my first build was a n/a d-series . it was quick it took out gsr and b16s but definite limits on n/a d-series. like top end , so i sold it and now working on this . thats cool tho whats it in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
Wow, ended up a lil pricey.</TD></TR></TABLE>
well lets see..
H22 long block 1200
CTR Tranny 1100
QSD h2b kit 750
Hasport mounts 400
Hasport shift linkage 150
Hasport axels 350
i also got an exedy clutch, fidanza flywheel, chipped p28 and a bunch of stupid **** that comes along with a swap like spark plugs, wires, new o2, oil, ect.
well lets see..
H22 long block 1200
CTR Tranny 1100
QSD h2b kit 750
Hasport mounts 400
Hasport axels 350
