going turbo/stock integra LS motor.
Old Apr 29, 2007 | 11:46 PM
JDM_CRX_PLEASE's Avatar
Default going turbo/stock integra LS motor.
i was thinking about going down the turbo route. i wanna do some research first and ask around.
whats the higest i can boost SAFEly for street use, such as daily driving, on my stock internals.
how much power could i be looking at.
i just want a little extra power for cheap $$$. so far my integra only has a GSR tranny w/ stage 1 exedy clutch and 8lbflywheel. its great fun, the motor has a bit over 170K on the motor.
she has never given me any problems, i love the car to death and treat it well.
thanks
oh also, im gonna be building a b20vtec on the side inside my room, so this is just a temporary thing, just for some extra fun.
Old Apr 30, 2007 | 12:33 AM
7mile's Avatar
Default Re: going turbo/stock integra LS motor. (JDM_CRX_PLEASE)
im in the process of getting a turbo kit in my ls as well.. let me know how it goes..
Old Apr 30, 2007 | 12:45 AM
no2unenolife's Avatar
i ran my stock ls turbo for a good 15k miles until i decided to swap.
if you have the correct parts and a proper tune it should last you a good while.
i was on a t3/to4e w/ around 9psi and was tuned on crome by church automotive
gluck
Old Apr 30, 2007 | 01:40 AM
how much power were u making?
i was thinking of only boosintg around 6 - 8psi.
just alittle something extra just to play around with. cuz my car is decent looking, but the power isnt there to back it up :[ ii get mad when stis rev on me and i cant do a damn thing but look pretty at the redlights :T
Old Apr 30, 2007 | 02:18 AM
1DA2NV's Avatar
on stock internals you shouldn't go over 5psi, even with a tune, the internals were not made for forced induction and you WILL have problems, as many PPL here on HT know the rule of thumb in modding your car is the big 3
FAST
RELIABLE
CHEAP
Pick 2
Old Apr 30, 2007 | 06:01 AM
95integraLS003's Avatar
Default Re: (1DA2NV)
10 psi on my DD stock block LS, i obtained 270whp off it! Got tired of 270 and building new block for 400 :-)
If you turbo it.. pay a little extra make sure the parts your getting are worth it, and build a solid kit, dont skimp out and you should be fine.
Leak down test and Compression test is a MUST! to make sure the motor is in good shape for this!
Old Apr 30, 2007 | 06:04 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1DA2NV &raquo;</TD></TR><TR><TD CLASS="quote">on stock internals you shouldn't go over 5psi, even with a tune, the internals were not made for forced induction and you WILL have problems</TD></TR></TABLE>
Dont listen to this...there are many cars making into the mid and upper 300s on stock internals, but i dont recommend it....
If you want your car to be fun and reliable, dont go crazy w/ power, but settle for something in the mid to upper 200s...Also, dont base ANYTHING on PSI as it means different things for different turbos.
Personally i would get a log or short ram, 3" dp and exhaust, T3/T04E 57trim (or GT3251E if you have a little more money), and get that setup tuned....you should be able to make 250-300whp on that on less than 11psi (stock map sensor limit)....The FI forum has a lot more info for you if you need....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integraLS003 &raquo;</TD></TR><TR><TD CLASS="quote">If you turbo it.. pay a little extra make sure the parts your getting are worth it, and build a solid kit, dont skimp out and you should be fine.
Leak down test and Compression test is a MUST! to make sure the motor is in good shape for this!</TD></TR></TABLE>
Stopsign32v
Feb 28, 2015 05:09 PM
wtsapexipowerfc
Feb 27, 2011 12:21 PM
fickel_8
Nov 10, 2006 01:27 PM
lsracer27
Apr 9, 2004 08:12 PM
Fooman
Oct 28, 2001 01:26 AM
