99-00 si brakes on 93 civic
Old Apr 29, 2007 | 09:14 PM
jdm2ltrcpe's Avatar
Default 99-00 si brakes on 93 civic
Ok the question i have before i buy this setup im lookin at is, What all do i need? i just dont kno what lcas i would i use. i have omni lca's on my car now and i was wondering if they will work on the ek setup? and i dont feel like buyin another set cuz i noticed that omni makes a different lca for ek's. another question is can i jus swap the disc spindles on to the stock eg trailin arms? and jus use si e brake cables and hoses? or do i have to use the whole si setup?
tried searchin couldnt find anything that said what i wanted to kno.
Old Apr 30, 2007 | 01:24 AM
BlueIntegraBoy's Avatar
Default Re: 99-00 si brakes on 93 civic (jdm2ltrcpe)
Yes, use your Omni's. EK LCAs are too long. It is possible to swap just the brake portion onto the stock trailing arm.
https://honda-tech.com/zerothread?id=426445
Old Apr 30, 2007 | 02:06 PM
jdm2ltrcpe's Avatar
thats what i thought about the ek lcas. ok thanks for help on that one,
now i have another question
if i use the stock trailing arms what brake hoses and what ebrake cables would i need.
Old Apr 30, 2007 | 06:47 PM
Default Re: (jdm2ltrcpe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm2ltrcpe &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought about the ek lcas. ok thanks for help on that one,
if i use the stock trailing arms what brake hoses and what ebrake cables would i need.</TD></TR></TABLE>
The ones that come with the disc brakes. Don't reuse any drum components.
Old Apr 30, 2007 | 07:16 PM
JDMFreak's Avatar
i think your better off with 94-95 EX-ABS setup...it will be cheaper (due to Si Parts), and it the same as GSR
Old Apr 30, 2007 | 08:22 PM
Default Re: 99-00 si brakes on 93 civic (JDMFreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak &raquo;</TD></TR><TR><TD CLASS="quote">i think your better off with 94-95 EX-ABS setup...it will be cheaper (due to Si Parts), and it the same as GSR </TD></TR></TABLE>
Uhhh, 92-95 Civic ABS, 92-95 Civic Si, 93-97 Del Sol Si, 94-97 Del Sol VTEC, 99-00 Civic Si, 90-01 Integra = all the same rear disc brakes.
Old Apr 30, 2007 | 08:42 PM
jdm2ltrcpe's Avatar
So i would use the 99-00 civic si ebrake cables? cuz i thought i read some where that you use integra ebrake cables for 92-95 civic.
Old May 1, 2007 | 12:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm2ltrcpe &raquo;</TD></TR><TR><TD CLASS="quote">So i would use the 99-00 civic si ebrake cables? cuz i thought i read some where that you use integra ebrake cables for 92-95 civic.</TD></TR></TABLE>
You can probably use the Si ebrake cables.
someforlight
Mar 22, 2006 04:19 PM
SPD DMN
Mar 25, 2005 12:24 PM
ea_hatch
Dec 4, 2004 08:03 AM
eg ferio
May 4, 2004 07:53 AM
evil_elmo
10
Jan 3, 2003 04:31 PM
