how to change fuel filter
Old Apr 29, 2007 | 09:11 PM
ezol's Avatar
Default how to change fuel filter
I got a 2000 accord 4cyl. Just wondering if someone has a diagram on how to change the fuel filter. My car seems to be dying on me when i start it sometimes, thinking maybe that will help it. Thanks
Old Apr 30, 2007 | 07:18 AM
hondadude's Avatar
Default Re: how to change fuel filter (ezol)
It's a sock on the end of the fuel pump pickup inside the gas tank.
if it was plugged up you would have other problems like stumble under throttle.
Old Apr 30, 2007 | 11:06 AM
Rainy City's Avatar
Default Re: how to change fuel filter (hondadude)
Is that where they keep it on the accords? its on the firewall for us civics.
Old Apr 30, 2007 | 04:39 PM
Mjfan12's Avatar
the other guy must have it confused with the pump. the filter is in the egine bay near the firewall 99% of the time.
I also want to change mine but don't know how. I mean I know, but i need to know how difficult it would be for me to do it.
Old Apr 30, 2007 | 04:47 PM
The-Kid's Avatar
Correct me if im wrong. I believe from 6th gen accord (like yours) You don't have a filter. The 5th gen accord do.
Old May 4, 2007 | 12:20 AM
under_the_hood's Avatar
its on the firewall! on the passenger side I have a 90 accord. I installed mine 20min very simple wrench sizes are 10cm 12cm an 11/16 socket. ADVISE YOU USE THE WASHERS! ARE YOU WILL BE SQUIRTING GAS.
Old May 4, 2007 | 03:12 AM
streetxdreamer's Avatar
Default Re: (under_the_hood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by under_the_hood &raquo;</TD></TR><TR><TD CLASS="quote">its on the firewall! on the passenger side I have a 90 accord. I installed mine 20min very simple wrench sizes are 10cm 12cm an 11/16 socket. ADVISE YOU USE THE WASHERS! ARE YOU WILL BE SQUIRTING GAS.</TD></TR></TABLE>
you have a 90 accord he has a 2000, different years different generation.
I dont know about the i4's but i have a v6 and its just a sock in the gas tank like hondadude said
Old May 7, 2007 | 11:15 AM
fleetmack's Avatar
Default Re: (streetxdreamer)
don't mean to hijack, but how much of a difference will a fuel filter really make with regards to mileage? my mileage has gone to absolute **** since about december ...i've done plugs, plug wires, air filter, o2 sensor, and had it aligned ... i'm still about 5mpg less than i have been in the same months over the past 7 years. (95lx)??
Old May 13, 2007 | 04:24 AM
Blamm!!'s Avatar
Default Re: (fleetmack)
'99 and newer have a returnless fuel system with no canister fuel filter it is a sock screen type deal in the tank.
Old May 13, 2007 | 06:50 AM
Megaseth's Avatar
there could possibly be some correlation with the change in the gas mixture....with the newer blend and possbily summer blend, the gas mileage will go down.
1999accord
Apr 6, 2022 05:12 AM
ferreiae
Nov 13, 2018 03:33 PM
KDoGx504
Sep 7, 2016 12:29 PM
tshih
Jan 22, 2006 07:23 PM
AFAccord
Sep 10, 2005 02:17 PM
