d series high compression questions..... i am looking to have a 11.5
Old Apr 29, 2007 | 07:19 PM
superex87's Avatar
Default d series high compression questions.....
hey guys, i have a 91 crx dx it is currently stock, i am changing it over to mpfi
i have a spare engine block its from a 90-91 crx HF, i want to build this block to be a high compression engine that is reliable
i have serched for awnsers and am extreamly confused
i would like to use the p29 pistions with eagle rods, will this work?
some people say that the wrist pin location on the p29 rods is 3 mm higher which would result in the pistion sitting 3mm lower a TDC than the stock pistions resulting in a lower compression ratio, i am looking to have a 11.5 to 12.0 CR sooooo is this doable
Old Apr 29, 2007 | 07:27 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: d series high compression questions..... (superex87)
Honestly, I'd use another block first of all.
2nd why do you want that comp what cam and fuel will you be using?
You can make a 11.5 or 12:1 comp D no problem though if you give us some hints what you want out of it we can help you make a great setup.
Old Apr 29, 2007 | 07:45 PM
superex87's Avatar
Default Re: d series high compression questions..... (Ace$nyper)
id like to be able to make about 150- 160 hp, the reson that id like to use that block is that i already have it and it didmt cost me anything and it ran good when it was pulled
for the cam im not sure what id get but something semi agressive
i would run 92 octane all the time, umm are all si engine bock from the 88-91 crx a 1.6L?
Old Apr 29, 2007 | 08:03 PM
JUN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superex87 &raquo;</TD></TR><TR><TD CLASS="quote">id like to be able to make about 150- 160 hp,a 1.6L?</TD></TR></TABLE>
LOL
there is no way you will even get 120 to the wheels with that block/piston combination...
start reading
Old Apr 29, 2007 | 08:13 PM
superex87's Avatar
Default Re: d series high compression questions..... (JUN.)
i wasent sure as to how much power cound be made with a n/a d block so yea........
so what setup with the stock si block and si head would make alot of power n/a??
Old Apr 29, 2007 | 11:09 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. &raquo;</TD></TR><TR><TD CLASS="quote">
LOL
start reading
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superex87 &raquo;</TD></TR><TR><TD CLASS="quote">i wasent sure as to how much power cound be made with a n/a d block so yea........
??</TD></TR></TABLE> he wasn't saying with a "D" block, he was talking about your piston/block combo
Good D series high compression just off my head
A6 block "most people's favorite to start with"
Z6 head "Got to love the OBD 1" "Vtec overrated "
y8 IM "the type R of d series, but it is argued to be almost the same as the z6"
A1 pistons "higher compression right off the back"
and remember the ZC has a more agressive cam
Old Apr 30, 2007 | 01:22 AM
661rex89si's Avatar
damn you ryan you do know a1 pistons are p29's right dusty lol. dude there has been people using p29's and pm7 same pistons for low budget all motor set-ups.
its going to take a wee bit more compression to make 150-160hp try shaving the head a bit also build a motor with the type of cam you plan on using.
Old Apr 30, 2007 | 01:24 AM
661rex89si's Avatar
LOL
start reading
are you stupid you should begin reading 120 to the wheels is actually an easy number to pull off with those pistons and block your a moron lol. what a noob
Old Apr 30, 2007 | 07:36 AM
superex87's Avatar
Default Re: d series high compression questions..... (661rex89si)
thanks for the replies
so how much can be shaved off the block/head and still be a safe setup ....i.e still have pistion to valve clearence and yes i know im going to need an adjustible cam gear if i shave alot off
so its not realy worth using the HF block then?
Old Apr 30, 2007 | 07:39 AM
89efDUSTY's Avatar
Default Re: (661rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661rex89si &raquo;</TD></TR><TR><TD CLASS="quote">damn you ryan you do know a1 pistons are p29's right dusty lol. dude there has been people using p29's and pm7 same pistons for low budget all motor set-ups.
its going to take a wee bit more compression to make 150-160hp try shaving the head a bit also build a motor with the type of cam you plan on using.</TD></TR></TABLE> hahaha yah i know i just posted a set-up, i always use the motor codes because a lot of people know them compared to the piston number...
also, to the OP if you can find it there is a d series piston write up pretty good stuff...
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
aptyk88
Nov 3, 2008 08:27 AM
civicjoe
Apr 7, 2008 11:04 AM
onemanlan
May 24, 2004 06:50 PM
McFly
Jun 20, 2002 05:18 PM
