Once I get connect my P13 ECU, is there anything else I need to do.
My car has a OBD2A set up now with a H22A. It keeps stalling and running like **** no matter what I do. Everything thing points at the OBD2A set up. I just purchased a P13 ECU and a conversion harness to convert everything to OBD1. Everything except the Engine and distributor is OBD2A and the Crank position sensor is running threw a sensor in the OBD1 distributor.
Is there anything I don't need?
Can I use a OBD1 engine harness?
Should I put on the OBD1 intake manifold?
