throttle response and sticking...96' DC2
Old Apr 29, 2007 | 04:55 PM
AwOrKiNpRoGrEsS23's Avatar
Default throttle response and sticking...96' DC2
so over the last few days I've been noticing that my throttle has been sticking and no lowering down to idle rpm when i either put in the clutch or when i'm shifting etc...any one run across this problem? any help/troubleshooting would help.
Old Apr 29, 2007 | 08:59 PM
Default Re: throttle response and sticking...96' DC2 (AwOrKiNpRoGrEsS23)
anybody?....this is kinda an annoying problem that i'd like to fix...
Old Apr 29, 2007 | 09:54 PM
MrDomino's Avatar
im having the same problem but at random times
ill be driving at 3000 rpms and push in the clutch and the engine revs to 4000 rpms and sticks there
im guessing its probably the throttle cable sticking or a burr on the TB
anyone?
Old Apr 30, 2007 | 01:16 PM
Default Re: (MrDomino)
yea it sounds similar to me. my dad told me to tighten the spring on the throttle body or lube up all the joints at the pedal and see if that may help...
Old Apr 30, 2007 | 07:37 PM
Default Re: (AwOrKiNpRoGrEsS23)
i fixed the problem by the way,...i just moved the spring on the throttle body up another peg and it put more tension on the cable which pulled the pedal back to 0% throttle....or idle i guess.
shabam
14
Mar 14, 2008 12:17 PM
shabam
Dec 9, 2007 07:52 PM
shabam
Oct 9, 2007 05:10 PM
shabam
Oct 9, 2007 02:20 PM
si0385.
Feb 3, 2006 08:19 PM
