ACT XXTREME clutch feel?
Old Apr 29, 2007 | 03:17 PM
project civic's Avatar
Default ACT XXTREME clutch feel?
I have the six puck act xxtreme clutch (rated at 480tq) in my dd/turbo car and ive been driving the car for awhile now having to rev the engine to 2500 or higher rpm to get the car moving or else it stalls. Whenever i shift gears, its hard to get a smooth engagement without any vibrations. Is this normal?
Old Apr 29, 2007 | 03:34 PM
EJ6_Hatch's Avatar
you sure you need that strong of a clutch on your DD?
Old Apr 29, 2007 | 04:00 PM
Default Re: ({PBA}Threat)
Yes the car made 450hp at 15 psi and 300 tq. I'll be turning up the boost in the future. I just want to know of the clutch engagement is normal on my xxtreme clutch.
Modified by project civic at 5:15 PM 4/29/2007
Old Apr 29, 2007 | 04:31 PM
EJ6_Hatch's Avatar
ah ok.
Well, can't help ya out on that one.
but I'll bump ya
Old Apr 29, 2007 | 05:23 PM
Otherguy's Avatar
NASIOC.com
Your going to need to get stiffer mounts
Old Apr 29, 2007 | 05:58 PM
Default Re: (Otherguy)
i already have urethane inserts and hasport driverside mount.
Old Apr 29, 2007 | 06:10 PM
robble36's Avatar
Default Re: (project civic)
its normal your going to get vibrations and of course its heavy duty it isn't some flimsy ****... if its new then after the 500 mile break in everything kind of sets in and the pedal feel will be different also after you drive it for about 300 miles out of the 500 .. basically the vibrations are normal and about the 2500 rpms .. if its new there is minimal slip also there is already minimal slip because of what it is .. just break it in.. everything you described sounds like a new clutch
Old Apr 29, 2007 | 06:21 PM
Default Re: (robble36)
Thanks
blkbb6
Dec 8, 2011 04:39 AM
mark_dc2
Aug 25, 2010 11:34 PM
Chaser4dr
Aug 16, 2007 06:05 PM
Stock@$$GSR
Dec 16, 2003 03:05 PM
zomart
Jul 23, 2003 05:51 PM
