Looking into a tap and die set
Yes, for some reason this is one thing I have never bought, how does this kit seem ? Does it seem to cover all the common Honda bolt sizes ?
http://www.sears.com/sr/javasr...e=Yes
Thats a tread chaser set.It's only used for cleaning up existing threads.Stay away from sears for tap and die sets.They are low quality.My best experience has been buying the taps I need from MSC online.
Been trying to look at there site but its down. I missed that it was just a chaser, how about this one then, for now atleast. Until MSC is working
To tell you the truth I wouldn't bother with a set.You will rarely ever use a die.Honda uses a lot of pitches that you won't find in a set.The steel that is used in a sears set is crap.You will be lucky to tap a few holes before they are dull.
i agree, just pick up the tap you need at a local industrial supplier. the quality will be much better. some people hate them, but i find blue wizards aren't too bad for most applications. stay away from spiral flute taps since they are best used in cnc applications. also make sure you get some tapping oil to make sure your tap life will be optimized.
I have a big tap and die set from sears. Been using it for 2 years with no problems yet. Only new taps i've bought in the past 2 years are oddball sizes that weren't included. The 1 major tap you'll need for a honda that's not included in the big craftsman set is an M12x1.25 for tranny/motor mount bolts.
From: Where thieves get shot in the face,, texas, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I have a big tap and die set from sears. Been using it for 2 years with no problems yet. Only new taps i've bought in the past 2 years are oddball sizes that weren't included. The 1 major tap you'll need for a honda that's not included in the big craftsman set is an M12x1.25 for tranny/motor mount bolts.</TD></TR></TABLE>
What he said
What he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">My best experience has been buying the taps I need from MSC online.</TD></TR></TABLE>
I agree.
We are a good sized manufacturing plant that has tried just about every tap vendor around. As far as mixing quality, price, availability its hard to beat MSC. I don't buy anything else from them as I prefer other vendors for everything else. You could spend less than the $80 the Sears kit cost and get everything you need at MSC.
I just checked.... their site is working fine.
I agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I have a big tap and die set from sears. . . . . . .The 1 major tap you'll need for a honda that's not included in the big craftsman set is an M12x1.25 for tranny/motor mount bolts.</TD></TR></TABLE>
Been using mine for a couple of years with no problems. I use them mostly on aluminum but they have worked fine with steel when I have needed them to.
Thanks guys
But what do you know ?
I bought a tap from car quest just to hold me over, how do you guys get the nice area right at the beginning ? Almost like a countersunk screw hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">M12x1.25</TD></TR></TABLE>
The one to get. Damn it sucks when you try to go everywhere to find one. Haha. J&L have them. Thats where i got mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">I bought a tap from car quest just to hold me over, how do you guys get the nice area right at the beginning ? Almost like a countersunk screw hole. </TD></TR></TABLE>
noooo!!
you shoulda just got the one from sears! Gotta love the lifetime no questions asked warranty!!
noooo!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">
noooo!!
The sears over here never has any in stock.
noooo!!
</TD></TR></TABLE>The sears over here never has any in stock.
You should really buy at least 2 sets of taps, 2 flute taps for aluminum and plastics and 4 flute for steels and harder alloys. There are also cut taps and bottoming taps which are needed depending on application. For blind holes use a cut tap and finish with a bottoming tap etc.
I dont remember off hand what I used for taps when I was a machinist but for endmills we used fullerton tools and they were the best I have seen. Most of the American tooling companies are really good. Stay away from stuff made in Japan or China.
Believe it or not, Harbor Freight has one of the most complete Ti coated tap and die sets I've seen. I was at a local Porshce shop and saw a nice metric tap/die set and inquired about where they got it - HF! Said they had been using it for years. I bought metric and sae sets from them - both for under a hundred bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">you shoulda just got the one from sears! Gotta love the lifetime no questions asked warranty!!
I'd have to double check but I'm almost positive that taps/dies and are NOT covered under the lifetime warranty. I believe it's only a 90 day.
-Schuyler
</TD></TR></TABLE>I'd have to double check but I'm almost positive that taps/dies and are NOT covered under the lifetime warranty. I believe it's only a 90 day.
-Schuyler
Ive just collected taps I needed over the years, but if I needed a particular tap I would just buy one at a time for the local supply house because it would be the right one for the job. I also buy boxes of taps at auctions for $10-50 because large taps are so expensive.
B18CJDM
Aug 15, 2001 07:30 AM
