D15 injectors in a B16???
Old Apr 29, 2007 | 12:30 PM
dkboyny11's Avatar
Default D15 injectors in a B16???
Just had a problem getting my new swap started. I diagnosed it to be the injectors, and then swapped out the injectors from my stock motors injectors. The car started now with the other injecotors, but I'm not sure if they are big enough to use perminently with my B16??? Thanks
Old Apr 29, 2007 | 12:43 PM
SOHCEK-Turbo's Avatar
Default Re: D15 injectors in a B16??? (dkboyny11)
What injectors did you have in there before, b16 injectors should be 240cc the same the D series Z6 and other 1.6 sohc use. So if you have those on you shouldnt have a problem.
Old May 3, 2007 | 03:54 PM
dkboyny11's Avatar
Default Re: D15 injectors in a B16??? (SOHCEK-Turbo)
Ya, I only had the 180cc injectors that came with the stock d15. They worked to make the car fire right up but I'm not going to try and beat on the car with them in there.
Old May 3, 2007 | 04:30 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkboyny11 &raquo;</TD></TR><TR><TD CLASS="quote">Ya, I only had the 180cc injectors that came with the stock d15. They worked to make the car fire right up but I'm not going to try and beat on the car with them in there. </TD></TR></TABLE>
All D series are 240cc. Talked to a honda technician.
Old May 6, 2007 | 03:06 PM
Default Re: D15 injectors in a B16??? (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
All D series are 240cc. Talked to a honda technician.</TD></TR></TABLE>
No 92 CX are 180cc.
Old May 7, 2007 | 02:14 PM
dkboyny11's Avatar
See that's what I thought too. I looked it up and that was what I found for an answer for injector size on a 95 CX.
umair
May 31, 2011 07:22 AM
blackcrx16
Jul 23, 2007 04:41 PM
craiger
Sep 6, 2006 09:28 AM
cmyrex
16
Oct 13, 2005 05:38 PM
