Engine I.D
Old Apr 29, 2007 | 12:21 PM
wernhersey's Avatar
Default Engine I.D
(I realize that this is kind of a broad topic but I am just looking fora little info.)
Can anyone tell me what engine is in a 87 crx si auto, and what are some specs on it, like who much does it way? thanks
Old May 1, 2007 | 06:26 PM
CodyC142's Avatar
Default Re: Engine I.D (wernhersey)
bumptizzle
Old May 1, 2007 | 06:31 PM
92civicfreak's Avatar
they made an si auto?
Old May 1, 2007 | 06:33 PM
CodyC142's Avatar
Default Re: (92civicfreak)
suuuure did
Old May 2, 2007 | 03:11 PM
CodyC142's Avatar
Default Re: (CodyC142)
anyone know what the code is for the engine for a 87 crx si?
Old May 2, 2007 | 03:20 PM
MagnaniEG6's Avatar
go on google and search for redpeperracing auto no sure they came in auto
Old May 2, 2007 | 03:21 PM
CodyC142's Avatar
Default Re: (MagnaniEG6)
I gaurntee this car has an automatic transmission, if no one believes me, Ill go over and take a picture, and so everyone
down for some info on the motor
Old May 2, 2007 | 03:22 PM
slprhndaboii88's Avatar
i think its a d16z1 maybe?... and yeahh they did make and si auto belive it or not
Old May 2, 2007 | 03:23 PM
CodyC142's Avatar
Default Re: (slprhndaboii88)
so the motor is a d series? I wasnt sure what came before the 88. It looks like no d series Ive seen before.
Old May 2, 2007 | 03:25 PM
Ermil's Avatar
it's a 1.5 litre fuel injected motor
EW1D15
Old May 2, 2007 | 03:33 PM
wernhersey's Avatar
Default Re: Engine I.D (Ermil)
No its a 1.5 carbureted. And it definitley is an auto SI.
Old May 2, 2007 | 03:56 PM
aarontrini85's Avatar
no way in hell its an si if its carbureted
and if you want to do a mpfi swap on it i have all the **** you need ecu harness and all hell i have the car to just no motor
Old May 2, 2007 | 09:45 PM
wernhersey's Avatar
Default Re: Engine I.D (aarontrini85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">no way in hell its an si if its carbureted</TD></TR></TABLE>
Do I need to show you people pictures or what. Its a 1987 honda crx SI automatic. It it powered by a 1.5 liter carburated engine. Not throttle body, not fuel injected, CARBURATED! I can't believe you people don't believe me. I don't lie about being under powered.
Old May 3, 2007 | 03:19 AM
then some one messed up that car check the vin and see what options it should of had becouse it shoudl be fuel injected if its an si
Old May 3, 2007 | 08:15 AM
wiZCo's Avatar
Stouts 'n' Scotch
Goddamnit! The Si did not come with an automatic or DPFI stock. It has to be MPFI and a 5-speed if it's the stock motor as the Si was introduced specifically to market the new MPFI and PGM-FI system (Si = sequential injection).
Somebody must have swapped out the 5-speed and engine, you do not have the stock engine and trans. You have an Si shell with lesser parts. Period.
You can check the engine code by looking on the block near the #1 exhaust port where the engine and transmission mate.
Do your research, I googled "1987 CRX Si" and this was the first link: http://www.musclecarclub.com/o...shtml
Hope that helps
Old May 3, 2007 | 08:33 AM
89efDUSTY's Avatar
Default Re: (wiZCo)
d15a2 for the carbed d15a3 for the MFI both SI and other model are 1.5...1.6 on CRX for USDM did not come till 88
I bet it is the normal base model and someone slapped on the badge and a sunroof....seriously though both 1.5...fuel regulation is the difference.
Old May 3, 2007 | 08:44 AM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wernhersey &raquo;</TD></TR><TR><TD CLASS="quote">
Do I need to show you people pictures or what. Its a 1987 honda crx SI automatic. It it powered by a 1.5 liter carburated engine. Not throttle body, not fuel injected, CARBURATED! I can't believe you people don't believe me. I don't lie about being under powered.</TD></TR></TABLE>
in 87, there were no AUTO crx si's (*i worked for honda by the way)
they were fuel injected too. this is 49 state specific.
here is a photo of the throttlebody and intake manifold:
Modified by STREETWERKZ at 10:08 AM 5/3/2007
Old May 3, 2007 | 08:57 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Engine I.D (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">in 87, yes there were AUTO crx si's (*i worked for honda by the way)
Was that just an option at the time? I know it's not stock.
Old May 3, 2007 | 09:04 AM
Default Re: Engine I.D (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
Was that just an option at the time? I know it's not stock.</TD></TR></TABLE>
well, not in the US. maybe someone in canada will chime in.
i meant, NO automatics.
CB7vtec still works for honda, i sent him the link, hes gonna come in here and tell everyone that 85-87 civic si and crx si were ALL 5-speed and ALL fuel injected. i just got off the phone with him and heard him typing away in the american honda parts catalog.
Modified by STREETWERKZ at 10:17 AM 5/3/2007
Old May 3, 2007 | 09:16 AM
89efDUSTY's Avatar
gonna come in here and tell everyone that 85-97 civics and crxs were ALL 5-speed and ALL fuel injected. </TD></TR></TABLE> you mean SI model right? because still carbed 85-87 correct?
I don't lie about being under powered.</TD></TR></TABLE> you can make tons of power with carbs...mmm Webber
Old May 3, 2007 | 09:18 AM
Default Re: Engine I.D (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> you mean SI model right?
yes, i went back and re-wrote it. i even typed 97 crx when i meant 87. DAMN THESE FAT FINGERS!
Old May 3, 2007 | 09:20 AM
89efDUSTY's Avatar
yes, i went back and re-wrote it. i even typed 97 crx when i meant 87. DAMN THESE FAT FINGERS! </TD></TR></TABLE> bwhahaha
Old May 3, 2007 | 09:24 AM
you had a 1st gen crx didnt you?
school this newb.
Old May 3, 2007 | 10:37 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">you had a 1st gen crx didnt you?
school this newb. </TD></TR></TABLE> hahaha yah i posted the ID he wants and telling him it cant be carbed SI...maybe JDM had something like that...but then i think his post would be regarding the Ballade SI RHD not the Carb
torsion bars FTW
Old May 3, 2007 | 10:41 AM
gibsanez's Avatar
Is he ignoring the fact that SI stands for Sport Injection?
