Carnage!
Old Apr 29, 2007 | 08:37 AM
MatHadder's Avatar
Default Carnage!
I just got around to tearing down the motor in my new civic this weekend. Check out what I found!
Do you guys think this is repairable?
Old Apr 29, 2007 | 08:42 AM
IP RACING's Avatar
Default Re: Carnage! (MatHadder)
If I was you I would just buy a new head it will cost you the same or more to repair that(if even repairable). how long did you drive on it like that for
Old Apr 29, 2007 | 08:45 AM
91ed9's Avatar
Default Re: Carnage! (IP RACING)
ohh nooo!
i would buy a new head also bc the cam might be chewed up but that means the journals are also chewed up!!! and yo really cant resurface them bc then your clearance wil lbe wayy off!
Old Apr 29, 2007 | 09:19 AM
MatHadder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IP RACING &raquo;</TD></TR><TR><TD CLASS="quote">If I was you I would just buy a new head it will cost you the same or more to repair that(if even repairable). how long did you drive on it like that for</TD></TR></TABLE>
Yeah, i was joking about repairing it. I already picked up a new head for it at the junkyard. I think there is something wrong with the oil pump, though, since I dont seem to be moving any oil.
I knew the cam had siezed when I bought the car, and never really planned on running this engine at all. I just figured people on here would like to see the carnage.
Old Apr 29, 2007 | 09:31 AM
*Boostwerks*'s Avatar
Looks like the oil hadn't been changed in a realllly long time either.
Was it full on oil?
Old Apr 29, 2007 | 09:33 AM
No2Pencil's Avatar
that oil looks NASTY man... i would **** myself too if i was ur head...
in for the rebuild tho
Old Apr 29, 2007 | 09:52 AM
MatHadder's Avatar
Default Re: (Boostwerks.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">Looks like the oil hadn't been changed in a realllly long time either.
Was it full on oil? </TD></TR></TABLE>
No, it was basically empty. I refilled it and tried cranking the motor over this morning, though, and I dont seem to be getting oil pressure, and there is no oil moving up to the head, so I think the oil pump might not be working.
Old Apr 29, 2007 | 09:04 PM
djphonics's Avatar
Default Re: (MatHadder)
Looks salvagable. Just needs some JB weld.
Old Apr 29, 2007 | 09:53 PM
MatHadder's Avatar
Default Re: (djphonics)
yep. JBweld was all it needed. car is running again now.
Old Apr 29, 2007 | 10:24 PM
turbodcivic510's Avatar
good to hear!
Old May 1, 2007 | 07:58 AM
papapitufo187's Avatar
Default Re: (turbodcivic510)
jbweld is awsome!!
Old May 1, 2007 | 08:59 AM
SETI20's Avatar
Wow. I've never seen that much carnage on a cam before. Even on -really- poorly maintained cars.
Aftermarket crappy cam?
Old May 1, 2007 | 10:04 AM
MatHadder's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Wow. I've never seen that much carnage on a cam before. Even on -really- poorly maintained cars.
Aftermarket crappy cam?</TD></TR></TABLE>
nope, bone stock d16a6, 205k. I think he just ran out of oil, but that still doesnt explain the horrific damage. Ive seen cams sieze before and just have a little bit of aluminum fused to the cam. This thing had damn near 1/8" of steel machined off the cam on two different journals. It is amazing that it was able to transmit enough torque through the timing belt to cause this much damage without it seizing earlier. I bet it was making some pretty terrible sounds before it finally siezed...
91bluehatch
Texas -OK -LA (Sales)
Apr 3, 2009 02:27 PM
R59
Jan 3, 2006 10:31 AM
cvp467
92
Sep 26, 2005 10:47 AM
soundbomber
Apr 8, 2004 01:24 PM
