90 Accord Distributor
My 90 DX distributor has begun to leak oil at the base. Is this a quick fix by replacing a seal? I also have a spare distributor from a 91 EX, is this a direct swap?
Thanks for your help, this is post numero uno for me .
Jim
It should be easy. There is a rubber ring at the base of the distributor shaft. First MARK the position of the distributor and the rotor, and pull out the distributor. Replace the seal with a new one and put the whole works back is, in the SAME position as before. That should do it.
mellowman164
Jan 12, 2014 10:59 PM
blacktibby07
11
Feb 5, 2011 03:12 PM
